Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450
Blade 450 Blade 450 Helicopters Information and Help
Old 01-06-2012, 05:55 AM   #1
Vinno
Default Servo connection, forgot which was which.
Hey guys,
I started to troubleshoot the servo's and found one was dead but in my haste i started pulling all the servos out and now i forgot which order they go into the receiver..
Can any one tell me the order of the servo wires to the receiver?
First slot is bind, what order is the front servo, top servo and servo right under that one?
Thanks in advance.
Vinno is offline        Reply With Quote
Old 01-06-2012, 06:28 AM   #2
whoanelly
typical is this ,,
throttle = ESC
elero = top left cyclic or right doesnt matter.
elevator = is front cyclic servo
Gyro= Gyro (3 wires)
gain = Gyro (one signal wire)
Aux1 or pitch = top right cyclic servo
700LE : 105HZR AR7200BX JR8917 Multi gov , JR9503
600ESP : 100AMP Castle. Scorpion Motor . AMA #962896
400 Blade : Scorpion 2221-6 ,Castle ICE 50 Sonix Head and t
Align 450 pro V2 3G MKS DS95 MSR , 2 x MCPX (brushless C05 & HP05), Blade 130X.
whoanelly is offline        Reply With Quote
Old 01-06-2012, 11:09 AM   #3
Vinno
Still kind of confused sorry lol.
Is there a blade 450 wiring diagram around with the stock receiver?
When you say top left, are we looking from the front or tail?
Old 01-06-2012, 01:18 PM   #4
whoanelly
looking from the rear of the Heli , but those two can be either or aleron or aux 1 ,it doesnt matter. ..what RX are you useing ? does it show channels or a list like i gave you ? if its channels then just go down the list i gave you starting with ESC is channel 1
if when you get it in and the back two are reversed from the setting that you have in your radio u can just switch the two
Old 01-06-2012, 07:54 PM   #5
Scammer
Originally Posted by Vinno View Post
Hey guys,
Thanks in advance.
stock setup
1. bind
2. Thro = ESC
3. Aile = Bottom servo or left when tail pointed toward you
4. Elev = front servo
5.Rudd = gyro
6. Gear = gyro (yellow single wire)
7.Aux 1 = top servo or right when tail pointed toward you
Scammer is offline        Reply With Quote
Old 01-06-2012, 11:19 PM   #6
Vinno
Thanks guys, Helped a ton where would i be without yous.
