Old 01-06-2012, 07:04 PM   #1
densis
Default Trex 500 pro head problem
just pick up 500e pro with flybar and putting the head together the manual said linkage (A) is to be 31.5mm and linage rod (B) is to be 30.5 one of them is wrong need help
1: align trex 500EFL Pro DFC AR7200BX
E-Flite MCP x V2.0
Spektrum DX8 / DX18 Phoenix Sim
densis is offline        Reply With Quote
Old 01-07-2012, 03:18 PM   #2
nbells
Thats correct.
Linkage Rod A and Linkage Rod B are different links and go to different places
nbells
nbells is offline        Reply With Quote
Old 01-10-2012, 09:03 PM   #3
Van Edward
I had this problem as well, rod A cannot be made to 31.5mm with the 10mm rod and small links. Use the inside dimension of 2.5mm and it works out correct. I got this info from Gregor at Amain hobbies and it worked out fine good luck
Van Edward is offline        Reply With Quote
Old 01-11-2012, 06:41 AM   #4
nbells
Sorry, I misread what you were really after ..... I just rebuilt my head last night and this is what my settings were.....
Linkage Rod A should be 21.5mm
Linkage Rod B should be 30.5mm
Linkage Rod C should be 70.5mm
These are just arbitary settings and you still need to adjust pitch / tracking to suit afterwards.
nbells
