Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450
Blade 450 Blade 450 Helicopters Information and Help
Old 01-07-2012, 07:50 PM   #1
BitShifter01
Default Needing some help
Hello,
I just purchased a RTF Blade 450 3D. I charged the battery and tried to spool it up but when I do I get a very sever vibration. The tail hops up and down. I am afraid to spool it up because it is hoping so bad. I tried to adjust the gyro down but that doesn't seem to help. I also tried to tighten and losen the blades but that doesn't help either. It is suppose to be balanced from the factory so I may just see about returning it to amazon and getting another one to see if it's any better. Does anyone have any suggestions that I may try? I'm new to the 450 and really do not want to break anything.
Thank you so much in advance,
Ryan
BitShifter01 is offline        Reply With Quote
Old 01-07-2012, 07:54 PM   #2
Bob O
Member
It could be that the head isn't spinning fast enough to get the main blades straightened out, and the imbalance is causing the heli to wobble.
What are your throttle and pitch curves in normal mode? And how far up on the throttle stick are you getting before you back off due to the vibration?
Bob O is offline        Reply With Quote
Old 01-07-2012, 08:03 PM   #3
DesJardins
Sounds like the above mentioned where the blades aren't out straight as head speed is increasing.
Are the main blades really loose?
Blade 450X & Blade mCPX BL
Spektrum AR7200BX
ProgressiveRC's "The Neutrino Ticket"
DesJardins is offline        Reply With Quote
Old 01-07-2012, 08:52 PM   #4
Thalios
Yeah, they should be tight enough that if you put the heli on it's side, the blades don't fall off, but if you gently push on them, they can move.
Give it a touch more throttle. you'll see.
Thalios is offline        Reply With Quote
Old 01-08-2012, 10:01 AM   #5
BitShifter01
Default Throttle curve results.
Wow! Thank you all very much for replying! I am really afraid to spin it up much faster as the tail is bobbing up and down and it really seems out of balance. My throttle curve for norm is 0.0, 56.5, 72.5, 72.5, 72.5
for stunt it is all 72.5. That seems a little strange for me. I can take a video and post it if that would help explain what I am seeing.
Thanks again!
Ryan
Old 01-08-2012, 04:09 PM   #6
InFocus
If your sure the blade are not too tight, then another thing is to see if they're balanced. See the finless bob sections for helicopter setup here, as he has great walkthroughs for balancing blades.
Also, check that the tail blades are not too tight too. For me, the tail blades are almost floppy loose.
If the tail is bobbing, and not really vibrating, then maybe there something else going on, maybe flybar paddles.
Also, when you say bobbing, I assume you mean up/down. If the tail is wagging back and forth, we'd normally recommend to lower the gyro gain setting at the TX. But that would't make any difference if its an up/down motion.
Current fleet is getting smaller.
Blackout Mini-H, WarpQuad 230, Blade 200qx, Nano QX, UM F-27q Stryker, UM P51 Mustang, F4F Wildcat, DX6 radio.
Previous fleet: mcpx, 300x, 350qx,450x, qav400, DX7s
InFocus is offline        Reply With Quote
Old 01-08-2012, 07:32 PM   #7
Thalios
Just go back to the bible and go through the box opening verification.
Old 01-08-2012, 08:28 PM   #8
BitShifter01
what exactly do you mean? This Heli should have been all setup and ready to go.
Old 01-08-2012, 08:33 PM   #9
BitShifter01
What exactly do you mean by bible? This model was suppose to be RTF with no setup. Maybe I'm just being a little naive being new but that is my understanding. Thanks for you recommendations. Yes, when I say bobbing, I mean the tail is going up and down. To the point where the rear fin is hitting the table. I'm not going to spool it up any more. I am thinking about taking it back and exchanging it for another one. Do factory weighed blades need to be re-weighed? I haven't looked at the flybar paddles. Also the tail blades are sloppy lose like you recommend. Thanks everyone!
Old 01-08-2012, 10:19 PM   #10
InFocus
Hmm, table? I would not recommend spooling it up on a table. If you can, take it outside, on the ground, and spool it up. If you can, take a video and someone here will be able to quickly tell if this something normal or not..
With anything that is mass produced, mistakes can be made. HorizonHobby has very good customer service as well. I'm sure they'll be able to help if it comes to that.
Old 01-08-2012, 10:26 PM   #11
Thalios
Check the sticky thread called Blade 450 3D bible.
There's a section called box opening verification.
All you need is in there.
Old 01-08-2012, 10:34 PM   #12
ShaneJourdan
Originally Posted by BitShifter01 View Post
Hello,
I just purchased a RTF Blade 450 3D. I charged the battery and tried to spool it up but when I do I get a very sever vibration. The tail hops up and down. I am afraid to spool it up because it is hoping so bad. I tried to adjust the gyro down but that doesn't seem to help. I also tried to tighten and loosen the blades but that doesn't help either. It is suppose to be balanced from the factory so I may just see about returning it to amazon and getting another one to see if it's any better. Does anyone have any suggestions that I may try? I'm new to the 450 and really do not want to break anything.
Ryan
This is quite common.
The problem IS your blades are out of balance. You need to balance your blades. Tight or loose will make very little difference.
Helimax make a inexpensive one that works well. Or spend a little more and get better quality, they all work perfect when used correctly.
http://compare.ebay.com/like/3502444..._lwgsi=y&cbt=y
First you find the center of gravity, then you will balance the blades together. it will spin up smooth and it will fly better than you every thought it could.
Don't believe that these blades come balanced, they don't. Some may be close and most people just fly them. Then sometimes they are way off and this is the result.
I balance every set of blades because they just work so much better!!
Goblin 700 - XF495 KDE - HC3SX - CC160
Trex 700 - 700 MX - HC3SX - CC120
Blade 450X - Scorpion 2221-6 - BD3sx -CC 50
Gaui X2 - BD3sx - Talon 25 - DS95i
ShaneJourdan is offline        Reply With Quote
Old 01-08-2012, 10:36 PM   #13
ShaneJourdan
Please no offence but if this was true we would not need this forum.
Old 01-08-2012, 10:45 PM   #14
DesJardins
Spektrum AR7200BX
Old 01-08-2012, 11:01 PM   #15
ShaneJourdan
Originally Posted by DesJardins View Post
all in good fun....
Old 01-08-2012, 11:05 PM   #16
Thalios
ok. 95% of what you need is there.
Old 01-08-2012, 11:06 PM   #17
ianl9
The "bible" was wrote by a very helpful guy in this forum! He took the time to help many and you as well if you just take the time and read it you will see how helpful it is.
On a side note... I had that issue as well and blades were fine but the belt was way to loose
ianl9 is offline        Reply With Quote
Old 01-09-2012, 03:43 PM   #18
murrelet
I have purchased 4 Blade helli's with mixed results. The mcx2 was the only one that didn't need any work done on it. The 120SR needed a ton, still does, and the 450 needed blade balancing (and while I was at it, I balanced the homemade training gear as well). The mCPx v2 also needed a very slight blade balance (the bullets were good).
This might not be great analogy, but... if you bought new car/truck tires you'd expect them to be balanced as part of the purchase. Then take off down the highway and find there was a little shake, you'd go back and have them fine tune the balancing until they got it right.
Well, with RTF heli's, they come set up pretty close (there will always be exceptions) and it's up to you to fine tune the bugs out. This is part of the fun of dealing with them and some of the frustration as well. Read the BIBLE, get familiar with the toy you're going to be spending a lot of time and money on, and read this forum religiously and you'll begin to "get" it (I'm still deep in the fog, but there are clearing patches I'm happy to say).
I don't get why you're spooling up on a table. That implies an indoor, small room disaster in the making. Get the sucker outside, on the ground, with a training gear set attached (in case something is really amiss)....take it from me...like a good sim, training gear has saved me untold repair costs.
Blade Mcx2, Blade mCPx v2, Blade 120SR, Blade 450-3D
Real Flight 6 Mega Heli Pack, Phoenix
murrelet is offline        Reply With Quote
Old 01-09-2012, 04:31 PM   #19
InFocus
I was able to make my own blade balancer that works just fine..
What you need is:
A bolt that will fit through the blades, and 2 nuts.
|-------------Nut--Blade-Blade--Nut------------
Some folks use things like 2 small blocks on the exposed part of the shaft for the blades to balance on.
Tags
blade 450 3d
