Old 05-30-2007, 04:01 AM   #1
UncleBen
Default How to remove Starter Cup From Sullivan DynaTron???
Hey guys, I'm new here just got hooked on heli's. I've been trying to figure out how to remove the starter cup (the metal cup that holds the silicon insert for starting airplanes) so i can put on a hex adapter for helicopters from an old DynaTron has a little rust on the main shaft. So you pull, unscrew...I've tried everything this thing just wont budge.... Anyone remove the starter cup before?
UncleBen is offline        Reply With Quote
Old 05-30-2007, 05:17 AM   #2
WayneBrown
did one this past weekend. Apply heat as the nut and cup are locktited on, use a small pair of vice grips or good pliers to hold the shaft and an old rag to insulate your hand. Get it hot enough and it will just unscrew.
WayneBrown is offline        Reply With Quote
Old 07-26-2010, 07:24 PM   #3
Priapismic
I wish mine where that easy. I got the nut off. The cone is a different story. I used a pair of vice grips to hold the shaft and hit the end of the shaft with a propane torch and it still won't budge.
T-Rex 700 LE - T-Rex 600 NSP - T-Rex 500 ESP
Priapismic is offline        Reply With Quote
Old 07-26-2010, 07:46 PM   #4
Skiddz
Hit the cone with the torch, making sure ot heat it evenly. Should spin right off and if memory serves, it's a reverse thread.
-Kevin
Skiddz is online now        Reply With Quote
Old 07-26-2010, 07:48 PM   #5
Danal Estes
1) Take off locknut
2) Heat
3) Put on a THICK glove.
4) Attach the wires to a car battery BACKWARD.
5) Spin it up.
6) Grab the cup with the gloved hand.
Repeat 5 and 6, if required. After a couple of tries, it will thread itself right off. Sometimes even without the heat.
Trex 700E - SuziHans,V-Bar,JR8717/BLS251,X-Era 4030/3Y-460,12S Rhino 4900; SH frames are ~1 Lb lighter than Align 700E kit
Trex 700N - 7100R/JR8717@8V/GY611
About a dozen more, including 2xTrex 500 - 1 V-Stabi/6S, 1 Flybar/5S,GY770/DS3400G
Danal Estes is offline        Reply With Quote
Old 07-26-2010, 07:52 PM   #6
WillJames
Registered User
Originally Posted by Danal Estes View Post
1) Take off locknut
2) Heat
5) Spin it up.
Yea Baby, now that is what I am talking about!! Nice tip!!
William James
WillJames is offline        Reply With Quote
Old 04-03-2012, 07:52 PM   #7
airpup86C
2012 Update.
Found this thread while looking to see how to get my cone off. Here's a couple pics of my Dynatron after I got the cone off. Note, the threads are right hand, so the cone comes off the normal way. If you use the car battery method to remove the cone, you would hook the starter up to spin counter clockwise, which would be the way you would normally crank an engine.
I was unable to get mine loose using the battery method, As you can see, I ended up taking the starter apart and gripping the armature, and was able to easily remove the cone.
Al
T-Rex 500GF, Compass Knight 3D,Raptor E700, Rave 450
Newest member of the fleet: Synergy N7
Futaba 14SG
airpup86C is offline        Reply With Quote
Old 03-25-2015, 09:49 PM   #8
cyclenut
I had just decided to stick with the starter cup, and it had unscrewed, so, I red loctited it... then found a good deal on a Sullivan starter shaft here... I was aware of this thread, so got the heat gun out and gave that a go- no luck, perhaps with a full 24v, but I didn't have that laying around, so I ended up pulling the starter apart like airpup and was easily able to get it apart when I could grab the whole armature with my other hand. I am sure the heat helped a little bit, but the disassembly was the kicker that helped me over the hump.
--citizen 19-- ama#986265, T-Rex 700n 700e, 600n, 550e, 500 efl pro, 450 pro.. and a couple of planks...I am not a rep for anyone
cyclenut is offline        Reply With Quote
Old 03-25-2015, 10:57 PM   #9
Ace Dude
IIRC, I used a strap wrench to hold the shaft while turning turning the cone so I wouldn't mar anything. Since I get the strap wrench it's come in handy for other things around the house.
Ace Dude is online now        Reply With Quote
Old 12-25-2015, 05:24 AM   #10
halflife
1) Take off locknut
2) Heat
5) Spin it up.
Thank you so much!!! Works!!!
Regards,
Wolfgang
halflife is offline        Reply With Quote
Old 12-25-2015, 07:45 AM   #11
rcflier1
yes on the backwards. been doing that for years.i switch back and forth as I fly planks as well
rcflier1 is offline        Reply With Quote
