Go Back   HeliFreak > R/C Helicopter Support > Synergy Model Helicopters > Synergy Electric Models
Synergy Electric Models Synergy Electric Models Support
Old 01-10-2012, 01:04 PM   #1
Weule
Default E6/E7 cyclic ring
Hello,
I'm trying to determine the actual limits of the swash cyclic ring. At extreme throws there is interaction between the ailerons and the elevator (the elevator seems to run out of throw before the ailerons).
There is no actual binding. Coming from the align world I am used to the servo binding well before the swash interacts with itself.
Is there a general rule for setting the cyclic ring? I am using a Microbeast and BLS 451 servos on the low head position.
Weule is online now        Reply With Quote
Old 01-12-2012, 07:34 PM   #2
stevehof
Originally Posted by Weule View Post
Hello,
The 'general rule' is to set your electronic cyclic ring until there is no binding at whatever stick positions the Microbeast manual says to use when making that adjustment. Getting rid of interactions is usually not part of the cyclic ring function. Minor interactions with FBL shouldn't be a problem. Interactions that come into play only at max stick deflections are even less important.
2 - Synergy E7, Vbar 5 Pro, BLS255 & 256HV, Hacker Turnado 530 Edition/Quantum 4530-500, Rail 696/716, CC120/160HV, WR Sup BEC, Scorp BUG | Trex 500 ESP, ICE 75, Hacker 1600KV, 5245MG & 9254, BeastX, head/swash | Futaba 18mz
stevehof is offline        Reply With Quote
