Old 01-11-2012, 02:30 PM   #1
norstaroption
Default ICE 50 Lite and Align 450MX 3400 15T Pinion
Can anyone please post your setting for the CC 50 Lite Set RPM. I just picked up one. Motor timing and so on. Thanks in advance.
Synergy E5 Jive 100LV NEO
ATOM 500 YGE120 NEO
Nano QX 3D
norstaroption is offline        Reply With Quote
Old 01-11-2012, 02:43 PM   #2
Sirolf
I've got the same setup.
I run SetRPM at 2650, 2950 and 3200
PWM at 12kHz
Timing default at 5
Current limiting at insensitive (80A)
Gov gain 27
Initial spoolup 5
Headspeed changerate 12
KDS Chase 360 - BeastX Scorp HK2520-1880kV
Align Trex 600NSP DFC - BeastX - 91HZ-R CentreGlide
Align Trex 700E DFC - BeastX - Scorp HK4530-500kV
Sirolf is offline        Reply With Quote
Old 01-15-2012, 10:43 AM   #3
satgod
Governor mode
set RPM
auto-rotation enabled
governor gain 25
initial spool up 7
head speed change 5
brake (ALWAYS OFF on heli's)
current limiting 70a
cutoff type SOFT
motor:
start power 59
timing 5
direction forward
pwm rate 8 (2221-8 motor)
start with 8 on pwm fly it hard just bump it up just 1 notch fly it hard again and compare heat at the end of the flight
4 x Rush 750/stretched V-bar KDE 700XF-495 HV servos Greys reactor CC 160-HV
Trex 600EFL V2 V-Bar ds610 ds650 CC bec/pro Scorpion 130a HV KDE 600XF-530
450L KDE 1750 cc50 4xDS215MG k-bar
X-8 FPV Wing, TBS Discovery FPV, TBS Caipirinha FPV
satgod is offline        Reply With Quote
Old 04-29-2013, 10:37 PM   #4
Brianp82
The governor gains are supposed to be that high? What happens if its too low?
Brianp82 is offline        Reply With Quote
