Go Back   HeliFreak > R/C Electronics Support > bavarianDEMON/HeliCommand
bavarianDEMON/HeliCommand Factory Sponsored Bavarian DEMON and HeliCommand Support
Old 01-17-2012, 07:22 PM   #1
navzptc
Thumbs up HC3-SX Acoustic Hood Mods
After recently purchasing a HC3-SX and acoustic hood for it, I felt that it could do with a few mods so that the LED status could be seen and that satellites could be fitted without possible damage to the leads going to the unit.
The satellite plug problem was easily cured by cutting grooves in the foam to allow the plugs to be connected easily.
For the LED status to be visible, I obtained a clear plastic drink stirrer (type with a ball on the end) and ground the ball down until it was a hemisphere and the stirrer cut to the required length to project above the hood.
The cut ends were polished and then inserted into a hole which I had dremmelled into the hood above the LED, but countersunk so that no part of the HC3 unit was in contact. This was then hot glued into position.
As you can see this works very well, and is very cheap to complete.
Hope you find this of use.
Andy
As they say, a picture is worth a thousand words, so here goes:
ID:	281674   Click image for larger version
ID:	281675   Click image for larger version
Present Fleet:
Vario PHT3 EC-135.
Hirobo CH47 converted to Electric / Shaft Drive.
Trex 500 Seaking, EC-135 & Airwolf.
navzptc is offline        Reply With Quote
Old 01-18-2012, 06:10 AM   #2
DEMONjoe
Nice work, but keep in mind that any "open" part on the hood may not protect the housing of the HC from ultra-accoustic noise !
Just my technical comment, basically and personally I like your work :-)
Joachim
Joachim
CAPTRON Electronic GmbH
- bavarianDEMON Support, Product & Sales Manager -
DEMONjoe is offline        Reply With Quote
Old 01-18-2012, 09:18 AM   #3
Breezyjr
Just out of curiosity, why do you have to do this?
Joe_Breezy
Diablo, Shape 9.0, Goblin 700 & 380, Sylphide 90, Srimok 90N x2, Srimok 90E, Dune, Vibe 90SG, TDR, E-Aurora, Logo 600SE & 500SE, T600 ESP, T600NSP, Synergy E6 & E5, Warp 360, Gaui NX4 & X4,T500, T450 Pro FBL, 180CFX and 130x
Breezyjr is online now        Reply With Quote
Old 01-18-2012, 10:06 AM   #4
DEMONjoe
Because modern MEMS gyros are sensitive to ultra-accoustic noise, which is produced by the inlet wheels of turbines. Especially inside fuselages this may occur in sudden and unlikely corrections by the system, as it's sensors may be irritated by this noise.
Does not happen in many cases, but is not to be overseen.
That's why we treat the units in a special way during the production, mechanically and firmware, as well as offer this hood for the last half percent of possibly getting into any trouble :-)
Joachim
Joachim
Old 01-18-2012, 10:14 AM   #5
Breezyjr
Thanks... Makes sense....
Joe_Breezy
Old 01-19-2012, 03:50 AM   #6
DEMONjoe
It does, and believe me: you would not want to see what happens if you do not take care about that
Joachim
