Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mSR X
mSR X Blade Micro SRX Helicopters Information and Help
View Poll Results: Help? Anyone notice Performance increase?
Helpfull? 0 0%
Performance? 1 100.00%
Voters: 1. You may not vote on this poll
Old 01-18-2012, 11:03 PM   #1
Learnig2Fly
Default What I Learned the first month W\an MsrX
I'm a Newb to Flyin', But here goes: Was VERY unstable out of the box, but having only flown the coax'es before, just figured I sucked at flying a real bird, but after a few mods I was suprised at how nice it really is, so: Didn't like the stock blades, (me being a tinkerer), so I put MSR Blades on it, after cutting a littli bit out so they could fold, Very nice results, more lift, bit more stable, they are lighter, but wider, thought that would make for more drag, but the weight loss and lift more than make up for it, AND increased flight time! Then it came to the Balls on the Blade grips, WOW! how delicate. Ran out of MSR grips at the store, got some BMCX Lower blades, got some slop, couple of canopy grommets, got me flyin', But now the built in feathering pin breaks, changed the main rotor head over, filed the ends a little, Use the stock feathering pin o-ring on the plastic pin, and no slop whatsoever. These blades might even be lighter than MSR blades, BUT! they have built in Balls, AND are much easier to change after a crash. I am amazed at how stable this thing is now, and the performance increase helps me from crashing. When I changed the main rotor head over I had to raise the main shaft up to line it all up, Got some CF to make a new one, Stock one is long enough, but I want to be abls to switch back and forth, Tinkerer and all. Now the Tail rotor, I eventually went with an MPCX boom and rotor, But I've been giving my blades a twist for more umph when I spike the throttle. When I got it, got a couple of 160mah batts, haven't tried the 200+ mah batts with the skid change, like my CG as it is. By the way, The BMCX Lower blades are bout the same price as new grips, and the balls don't brak as fast and are easier o change. Hope that helps somone.....
Learnig2Fly is offline        Reply With Quote
Old 01-19-2012, 08:04 AM   #2
ebeing
I got a performance increase when I added Nano-Tech batteries.
The stock Bat seem weak in comparison.
ebeing is offline        Reply With Quote
Old 01-19-2012, 08:51 AM   #3
Learnig2Fly
Me too, Run it out after a mod or crash. LoL
Old 01-19-2012, 09:29 PM   #4
oshiri
It honestly sounds like you have worked too hard on that. But hey tinkering is half the fun.
oshiri is offline        Reply With Quote
Old 01-19-2012, 09:39 PM   #5
Learnig2Fly
Gosh, I hope not. New to helis, and it was available and cheep. Breaks less too, in my VERY humble opinion.....
