| Futaba CGY750 FBL System Futaba CGY750 Help and features Support Forum |
I have a CGY 750 setup on my T-Rex 450 Pro.
It seems to start off the flight pretty good, and go through most of the flight fine. But towards the end of the flight, it starts "kicking" left roll, just like a tail kick. I and D gain are at 40%, Aileron and Elevator are at 50%, Rudder is 33%, AVCS Dmp is 100%. Any ideas?
Team Miniature Aircraft USA Team HeliWholesaler, Team Byron Fuel's, Team Thunder Power, Team Scorpion -Darrick |
Belt driven tail? Static discharge perhaps...dry winter air. Just a guess.
Minicopter Diabolo-14s-Pyro 800-Kosmik-Vbar Kasama Srimok ECO CGY 750 Mini Prôtos CGY 750 |
Change the left aileron servo.
The servos are brand new.
I forgot to mention, this appears to only happen in idle up 2. I know what most of your first thoughts probably are, Yes I have the "combined" trim setup for aileron and elevator, it's the same in all flight modes. This is the 450 Pro with torque tube, so no static discharge.
FWIW on my 550 I run these settings:
Dgain - 40% Igain - 50% elevator+aileron gain - 76% tail gain - 55% 99% on the AVCSDmp
AMA Leader Member Team Futaba Raptor 90SE/YS91ST - T550E FB - T550E FBL w/CGY-750 |
#6 | |
Gaui X7 MSH Brain YGE160HV Xera4035-480 X475 FES MSH Brain YGE120 Xera4020 Gaui X5 MSH Brain YGE90HV Xera 4025 Gaui X6 vbar silver 5.3 YGE120HV 700mx ElektroRC.com field rep (YGE, MSH, LAHeli) |
#7 | |
I created a new model and reset all the menu's in the CGY750, and set the whole thing up from scratch again. We'll see if it does it again.
#8 |
try adjusting your throttle by a few points up or down just to change the resonance created at that exact RPM.
#9 |
Try relocating your sensor
Team Thunder Tiger Raptor G4, CGY 750,YS120 Raptor X50 FBL, YS60SR, CGY 750 Raptor 30 FBL, OS37, CGY 750 12Z, 14SG, 8FG |
#10 |
Thanks guys. I wound up resetting the thing to factory defaults, dropping throttle curve to 95%, and dropped gains to 50% on aileron and Elevator.
Still working on a few things. When I'm happy, I'll post my settings. Thanks!
#11 |
Getting closer, I think I'll have it just about all set this weekend.
Very happy with the unit now that I've got it close to being dialed in.
