Old 01-20-2012, 01:26 PM   #1
roblord
Default Servo issue/problem - need help
Need help..pleace.
Have setup my KDS 450sv with flymentor by using HeliBal, got the cfg file for KDS 450sv.
The thing is that after i set it up everything seems to be fine, BUT when i'm turning the stick on the radio to the right there is no reaction in the rightservo.(The right servo works fine otherwice)
Everything should be connected right...
Enyone that can tell me what to do...and im a nobe so please tell me in a language i understand
roblord is offline        Reply With Quote
Old 01-20-2012, 05:00 PM   #2
pril250
Have you set your TX to single servo operation?
Blade400
pril250 is offline        Reply With Quote
Old 01-23-2012, 02:27 PM   #3
roblord
Default my linkline suddenly don't work
Have adjusted my Tx to singel servo, now my computer can't find link line??
Do I have to uninstall and reinstall program and driver?
Have someone had this problem before?
Old 01-23-2012, 03:54 PM   #4
pril250
Depends what operating system your PC is. Win XP should have no problems.
Blade400
Old 01-23-2012, 04:05 PM   #5
Ivor Hill
I would guess that the most likely reason is a faulty lead. There have been a couple of reports of bad soldering bridging the conections. The last report was the small end and the owner was able to take it apart and scape away the solder.
Ivor Hill is offline        Reply With Quote
Old 01-23-2012, 05:00 PM   #6
roblord
Thank's for reply.
I will check my line and the soldering, it have to be that.
I'm using windows 7, had no problem linking up after installing driver and reboot (turnig of sign "stuff" in bios) that was a couple of day ago.
Thanks again
Will report back
Old 01-31-2012, 12:19 PM   #7
roblord
Thank you for all help.
reporting back.
Soldering was ok, but the black cable had a break near the big USB port.
And I had to reinstall driver again, had to reboot pc twice before it worked..?
Adjusted my Tx and the servo working just fine
Last sunday i was out trying, then my ESC went to h...
I'm wondering if this heli will fly..ever???
One qestion:
Ordered a new ESC (RCX 40A) and it is programmable.
Do I have to do that, or could I just "plug and play"?
Old 01-31-2012, 05:16 PM   #8
Ivor Hill
It will be plug and play but you should calibrate throttle high and low points. The instructions will explain. It is a pity you did not order the programming card makes it very easy to programme.
