Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Atom 7HV
Atom 7HV Compass Atom 7HV Model Helicopter Discussion
Old 01-26-2012, 12:01 AM   #21
chucky21022002
Originally Posted by skartun View Post
Tnx, but this is the right pinion if i want to go 14t? Mod 1?
All pinions for the 7hv is mod 1, just happens that revco makes hardened ones.
Sent from Samsung Galaxy S2
Copter X Hybrid Beast X
Trex 500 Vbar ,Trex 600 ESP 12S Vbar
Compass 7HV Mini V
Compass 6HV Vbar
chucky21022002 is online now        Reply With Quote
Old 01-26-2012, 07:11 AM   #22
chucky21022002
Originally Posted by Cullen Colapietro View Post
I'm running a CC Ice2 and Castle is only allowing me 1980rpm w/ a 14t. I have it set to 2000 and ignore the warning.
Could not agree more.
Compass 7HV Mini V
Compass 6HV Vbar
Old 01-26-2012, 07:13 AM   #23
heathy
Originally Posted by alexmit View Post
I found that motor with vBar gov and 12t seems to like over 2000, like 2100. Maybe it's a vBar thing, but mine felt a bit sluggish at 2000 with the same configuration.
Alex, what pinion did you end up with?? Or did you just up your headspeed?
X2 SK720 MINIJAZZ 20 / WARP 360 SK540 KOBY55 / E5 SK540 YGE120LV / LOGO 550SX SK540 HELIJIVE 120 / 7HV SK540 YGE160k / 7HV SK720 YGE 120k / TDR SK540 POWERJIVE 120 / Futaba18mz / Skookum support rep
heathy is offline        Reply With Quote
Old 01-26-2012, 08:23 AM   #24
Rob43
Tnx
For reference, I am running 14t with my 700MX-510, and getting around 2000-2050. It has excellent governor response with Kontronik.
In your case, I bet 14t will be perfect for the 2200 target. I'd like to hear how well you feel it holds...will it bog? You'll have enough headroom, but will the motor be capable of holding it? I am not sure. Please report back!
= R
b43 =
Team Compass Support
Rob43 is offline        Reply With Quote
Old 01-26-2012, 10:25 AM   #25
skartun
Will do! Just have to get the build finished and the heat up in the weather. A little less snow would hjelp to! :-) going skiing with my five year old now
Sent from my GT-I9100 using Tapatalk
Compass 7HV / 4x MKS HV / CC Ice2 120 / BeastX / S.Bus
Trex 450se V2 3GX
Trex 600N
HK450
skartun is online now        Reply With Quote
Old 01-26-2012, 01:25 PM   #26
dunkonu23
Cullen, which motor? I'm using an ICE2 with a 4036-560 and I can easily get 2150 without a warning.
Scott
Spartan Vortex VX1 Inside
Team A Main Hobbies/ProTek Field Rep.
dunkonu23 is offline        Reply With Quote
Old 01-26-2012, 02:06 PM   #27
heathy
Typical, the scorpion 12T pinion i had to settle on as the revco was out of stock is actually longer than the stock, going to have to sand it down to size a bit. Hope it doesn't cause any vibe problems
Old 01-26-2012, 04:14 PM   #28
alexmit
When i switched pinions I was abel to get the Revco 12T pinion. The stock 13T was eating my main gear every 8-10 flights for some reason. The Revco has a very different tooth profile, the Scorpion pinion is somewhere in between the Revco and the Stock pinion tooth profile. I'm thinking of switching my 6HV over to a Revco pinion now.
Atlanta RC Club, The only club inside the city.
SAB USA Field Rep. Canomod USA Field Rep. Pulse Battery USA Field Rep.
alexmit is offline        Reply With Quote
Old 01-26-2012, 04:17 PM   #29
heathy
As soon as the revco comes in its going on the 7hv.
Are you guys putting a smidge of retaining compound on the pinions?? The scorpion came with 2 grub screws.
Old 01-26-2012, 04:39 PM   #30
dunkonu23
I just used the one grub screw that came with the Revco. I did use 243 loctite on the grub screw because of the possibility of oil getting there, some how (Scorpion motor and all that...).
Scott
Old 01-26-2012, 04:44 PM   #31
heathy
I use red loctite on these grub screw, just after the stock pinion that either grew or slipped down into the bearing i think some retaining compound might be in order.
Old 01-26-2012, 05:04 PM   #32
alexmit
I've got my first 6hv motor sitting on the shelf with a pinion stuck on it. No amount of heat will take it off. I've only use blue Loktite on the pinion grub screws only. No issues if done properly.
Old 01-26-2012, 05:04 PM   #33
heathy
Is this style revco any good??
http://www.fast-lad.co.uk/store/revc...t-p-10410.html
The 1 i was looking at was this style
http://www.fast-lad.co.uk/store/revc...6t-p-9524.html
Any difference?
Old 01-26-2012, 05:25 PM   #34
Cullen Colapietro
Scott
Sorry Scott, thought we were all talking about the mx 510kv. I would like to try the 530kv, but they'e harder to come by cheap.
6HV|Warp 360| Compass Models | Prostar Hobby | MKS | EP Buddy | Team KBDD
Cullen Colapietro is offline        Reply With Quote
Old 01-26-2012, 06:50 PM   #35
dunkonu23
That's cool, Cullen. I was just wondering.
Scott
Old 01-26-2012, 06:55 PM   #36
alexmit
Any difference?
I prefer the 1st one. I think the reason my 7hv was eating main gears was the stock pinion along with main gear wobble. The stock pinion and your second choice is tapered and are less forgiving of misalignment or gear wobble.
Old 01-31-2012, 02:02 PM   #37
skartun
Sorry to bother you guys. But what do you do when the pinion is to high for the motor mount to come together be course of the track in the main shaft for the grub screw being to high?
(align 700mx 530kv)
-skartun-
Trex 450se V2 3GX
Trex 600N
HK450
Old 01-31-2012, 03:22 PM   #38
alexmit
(align 700mx 530kv)
-skartun-
use a dremel or file to make the slot in the motor shaft longer or taller in the direction needed. Poke the shaft through a plastic bag to keep the metal shavings from going into the motor and bearings.
Old 01-31-2012, 03:27 PM   #39
skartun
Tnx. Dremel it is then. :-)
Trex 450se V2 3GX
Trex 600N
HK450
