Go Back   HeliFreak > R/C Helicopter Support > Electric Micro/Mini Helicopters
Electric Micro/Mini Helicopters Electric Micro Helicopters Discussion
Old 01-21-2012, 09:03 AM   #1
S_W_A_T_Z
Exclamation WL V911 problem
Ok so I got this thing yesterday and when I took it out of the box, everything seemed to be in order. The motor was smooth, blades weren't warped, and in general it seemed like it was a decent piece of machine....
Well that wasn't the case. I started flying it and while it was in the air something seems to bind. I really don't know what it is and I don't really know where to look. It only seems to happen when the throttle is above half (which could mean absolutely nothing). I posted a video of it below. The vibration doesn't occur until 39 seconds in, but The rest of the video shows that it can fly around with no problem and then it randomly happens. Maybe someone can point me in the right direction?
S_W_A_T_Z is offline        Reply With Quote
Old 01-21-2012, 11:22 AM   #2
S_W_A_T_Z
So........ after a few hours of fooling around I think I fixed it. I took the flybar off and the wings off. Then I found that below the swashplate there is a brace with a single screw. Now when you really throttle it up the screw binds with the swashplate (causing the spasms you see in the video)
How I fixed it:
I loosened the screw just enough to slide the brace down a hair. Then I tightened it up and then I lengthened the linkage rods that connect to the swashplate (follow this vid for trimming, but just do the same thing to both rods
) By doing this I moved the swashplate up just enough so it doesn't catch on that damn brace screw. I put everything back together and made sure my flybar was extremely snug. Voila ! fixed. I'll post a video when I get a chance.
~Seth
Old 02-15-2012, 08:27 PM   #3
cklumm
Hi S_W_A_T_Z,
After fixed until now, does it happened again? Just wonder whether it happened due to fault of motor or servo. Mine is having the same problem.
cklumm is offline        Reply With Quote
Old 02-15-2012, 11:30 PM   #4
cklumm
Hope to see your video~~
Old 04-22-2012, 02:50 AM   #5
cyprusboy1
I have a V911 helicopter which flies well but after an encounter with a wall has quite abit od vibration. Any idea on how to diagnose and cure it?
cyprusboy1
cyprusboy1 is offline        Reply With Quote
Old 02-12-2013, 11:21 AM   #6
ulujm
Default sporadic tail
hi SWAT
could you put a video how to fix the problem when you do stuff on the brace below the swash bar?
thanks
jm
ulujm is offline        Reply With Quote
Old 02-12-2013, 02:24 PM   #7
Pfloyd
How I fixed it:
I loosened the screw just enough to slide the brace down a hair. Then I tightened it up and then I lengthened the linkage rods that connect to the swashplate (follow this vid for trimming, but just do the same thing to both rods http://www.youtube.com/watch?v=60dx2U1gw00 ) By doing this I moved the swashplate up just enough so it doesn't catch on that damn brace screw. I put everything back together and made sure my flybar was extremely snug. Voila ! fixed. I'll post a video when I get a chance.
~Seth
The video is of an Blade MSR!!
MCX/MCX2/MSR/MSRX/MQX/C105B/S300/MCPX/S107G/S107C/S109G/S108/S026/S009G/S023G/S102G/S110G/GYROPTER/
AIRRECON/UDI-803/UDI-816A/SYMAX1/V959/JXD-355/052INTERCEPTOR/EYE1/S113G/UDI-U810/
DX7s
USAF RETIRED (1968-1988)
Pfloyd is offline        Reply With Quote
Tags
v911 wl problem, vibration causes crashes
