Go figure, slap on some radix blades and dump the bird...Anyways, is the manual says to "R-48" smaller blade grip bearing. Can I just use loctite?
Thanks |
yepper.
the r-48 is thread lock
*** Why dont you go shave your big stink head with your bad self *** *** It sure does have some power ... but the tail sucks *** *** Every time I crash a kitten dies......so many lost kittens *** Dropping the F bomb as much as possible To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
You dont need to loctite the bearings into the grips. It makes it VERY hard to remove them later on down the track, and they cannot fall out in normal use.
Mick
So, what is R43?
She felt like someone of an ambiguous age that even neilg would approve of... |
Team Taco VP
DONT use locktite to place the bearings in the grips.... SUPER pain in the butt later... These bearings do NOT rotate at high speed or even rotate a full 360 so this is NOT a place to use R48 or any other locktite! You will HATE it later when it comes time to replace the bearings.
Assiemick is RIGHT ON! Bob
"Don't Taco My Pack Dude!" To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#6 |
Yeah baby, I'm right on!!
#7 |
Doh! well it may be a little late for that now
I dont remeber the bearings easily coming out, nor have tried, but the recent crash with new blades broke the spindle thus taking the grips with them. I reassembled the head by the manual and found the grip slides in and out on the bearings. Could I have bent the aluminum blade grips?
Team LPS "Just one more" 450 Pro, 450 V2 FBL, 600E, 600N FBL, Avant Aurora |
#8 |
As long as the grip still has the shoulder just on the inside of the small inner bearing then they should be fine. All loads are out in flight but are more than a bit of loctite will be able to hold.
Mick
#9 |
I see a shoulder or a race on the larger bearing side, but not one that prevents the smaller bearing from going all the way through. I tried to remove the bearings from the other grip to compare but couldnt, so is it time to buy new grips? BTW thanks everyone for helping out :wink:
