Old 01-22-2012, 11:33 AM   #1
sacko
Default KBDD Lime Green Dampers
Anyone used them in their 700E v2?
Are they a straight swap?
Trex 500ESP - Vbar v5, MKS 9660A, BLS251,
Outrage Velocity 50 - Vbar v5, Futaba BLS 351, Outrage 9080, OS55 all @ 8v
Kasama Srimok
sacko is offline        Reply With Quote
Old 01-22-2012, 11:37 AM   #2
Noahh
They are a very straight forward swap, just take the black stock ones out and put the green ones in, some users report vibes being they are so stiff.
Noahh is offline        Reply With Quote
Old 01-22-2012, 11:56 AM   #3
sacko
At least they are a straight forward swap I suppose.
Not too keen on the vibes mind you :S
Cheers
Kasama Srimok
Old 01-22-2012, 12:02 PM   #4
Noahh
Same here that's why I have stayed with the stockers.
Old 01-22-2012, 12:05 PM   #5
sacko
Mine suck though :S
Both of us at the field bought the 700E v2, and both have shot dampers after a handful of flights.
Kasama Srimok
Old 01-22-2012, 12:22 PM   #6
Noahh
Sounds like u should give them a try, I will pick up a pair Tuesday and try them out my self
Old 01-22-2012, 02:32 PM   #7
rcflyerheli
Maybe try a set of Trueblood greens.
Goblin 700, Trex 700 V2, Trex 700DFC, Gaui X7, Logo 600SX, Logo 690SX, Forza 700
Trex600EFL Pro, Trex 600 ESP, Trex 500 ESP, DJI 550
Amain Team
Rep
rcflyerheli is offline        Reply With Quote
Old 01-22-2012, 03:09 PM   #8
LegndarySaiyan
I have a set of the kbdd lime greens in my nitro and I like them alot. The heli already vibrates so I didn't notice anything new. I have a set waiting to go in my electric to try also but I'm pretty happy with the true bloods I'm currently using.
-Phillip Johnson, AMA #954735
LegndarySaiyan is offline        Reply With Quote
Old 01-22-2012, 03:15 PM   #9
Ah Clem
Make sure that you apply a thin layer of silicon grease to the KBDD Dampers. This will eliminate the Dampers as a potential source of vibration and will also make them last a great deal longer.
I am running them in a V1 Trex 700E (I don't have a V2 for testing, at them moment). The helicopter ran very smoothly with the stock dampers and there was no change in vibration level with the KBDD's-still very smooth. The only difference was crisper cyclic, IMHO.
Old 01-22-2012, 03:26 PM   #10
Mystic3D
Apply a little grease to the stock ones and they will last
Synergy N5C sitting in Box...
Mystic3D is offline        Reply With Quote
Old 01-22-2012, 04:13 PM   #11
sacko
Cheers all.
A UK KBDD sponsored pilot has offered me a set to try
Will give me the chance to see which varient I prefer before i buy a couple of sets.
Excellent support from KBDD.
Kasama Srimok
Old 01-22-2012, 07:06 PM   #12
esmoglo
Trueblood greens are very good no vibs at all with these dampers.
Angelo
esmoglo is offline        Reply With Quote
Old 01-22-2012, 07:17 PM   #13
akamullen
I tried the truebloods, but were a little hard for my liking, when I did some really low HS's the TB's were a bit to hard and gave me a wobble. I love the KBDD's, Very neat progressive design, soft around the center for softer low HS's flying, and hard when you push them doing hard 3D. almost like having two dampers at the same time.
AnythingHeli.com OWNER/ TEAM PILOT
GAUI X5 / X7 *
GOBLIN 380/500-x2/630/770 * Swinging SWITCH/RJX/RAIL & SAB Blades * Microbeast/IKON * Castle ESC's on all * DX18 *
akamullen is online now        Reply With Quote
Old 01-22-2012, 09:33 PM   #14
Glenn Goodlett
Have been using the KBDDlimes for about a week or two in my 700 nitro. I like them, they are definately softer around center than the green truebloods. The truebloods would wobble like hell during the end of an auto and the KBDD's not at all. If you want the hardest, or are worried about a boom strike, go with the truebloods. However the KBDD's fly better in my opinion.
Glenn
Glenn Goodlett is online now        Reply With Quote
Old 01-23-2012, 08:13 AM   #15
sacko
I'm hoping they are an improvement over the originals. I was planning on using the Truebloods, until I saw they were$19 over here!
Kasama Srimok
Old 01-24-2012, 10:45 PM   #16
Anthony440
I'm trying to install the lime green dampers in my dfc head with different results. They are making the bearings in the blade grips notchy, but the stock ones do not. I noticed they are thicker and stick out further than oem ... Anyone else have this issue or is it the dfc head?
Anthony440 is offline        Reply With Quote
Old 01-24-2012, 10:50 PM   #17
Ah Clem
Anthony440,
You may be the first one to try them in the DFC head.
By the way, sometimes when I install these on a 600, the bearings feel slightly notchy as well. This goes away after a flight or two.
The slight pre-load from the damperd is, by the way, nothing compared to the load imposed on the thrust bearings/blade grips by the centripetal force when the head is turning at flying speed.
Old 01-24-2012, 10:51 PM   #18
Ah Clem
Anthony440,
Make sure they are lubed and seated properly.
The slight pre-load from the Dampers is, by the way, nothing compared to the load imposed on the thrust bearings/blade grips by the centripetal force when the head is turning at flying speed.
Old 01-24-2012, 10:57 PM   #19
Anthony440
Thanks Ah Clem, I was hoping you would chime in on this. So you've experienced the notchy grips too then... Hmmm. I'm going to give them a run when my recalled parts for the dfc head come in. Thanks for the help!
Old 01-25-2012, 06:06 AM   #20
Chris_M
I actually had the same problem with both the stock and DFC head using the lynx spindle bolts. When I installed the stock spindle bolts the grips moved smooth but with the lynx bolts the thrust bearings were notchy. I found some brass .08 10mm ID spacers instead of the .09 spacers and that solved my problem. I installed 2 of them between the damper and bearing and it just gives enough space to the bearings while keeping everything tight with no slop. I only found these in a bag of 100 so I have lots of extras if you want me to send you some PM me your address and you can give them a try yourself.
Chris_M is offline        Reply With Quote
