Old 01-22-2012, 02:37 PM   #1
9sec240
Default MSH 50135 washers. Where the heck do you find them?
I can't seem to find these washers. They are used in the main grips and in the tail shaft. Looking at the pictures on MSH's website I can't seem to find them separately, with the grips or in the tail shaft / assembly. Where the heck can I get four of these? A used Protos I just bought is missing two in the tail and only has one bent up one in the head.
Thanks for your help.
ID:	282926   Click image for larger version
Ivan
There is a very fine line between "hobby" and "mental illness."
9sec240 is online now        Reply With Quote
Old 01-23-2012, 10:13 AM   #2
kavic5150
Post
Looks like 4 of them are included in the tail shaft package MSH 51006
http://www.readyheli.com/MSH51006-Ta...s_p_35525.html
http://helidirect.com/msh51006-01-ms...os-p-24395.hdx
They are also included in the main blade grips package but you dont get 4.
Hoss X4e 6s, Gaui 550, Protos 500 12s, Losi Speed-T.
Save the flybar !!
kavic5150 is offline        Reply With Quote
Old 01-23-2012, 12:01 PM   #3
alexf1852
You can also get a set of shims with 0.1, 0.2, and 0.3mm thickness:
http://www.amainhobbies.com/product_...5x7mm-Shim-Set
You get 10 of each.
MSH Protos * 2, SAB 630
alexf1852 is online now        Reply With Quote
Old 01-23-2012, 09:04 PM   #4
9sec240
Awesome info guys. Thanks so much.
Ivan
