| mQX Blade mQX Quad Helicopters Information and Help |
I finally got my MQX this evening and while charging my first battery, I started inspecting everything. My front left prop (from the rear) has a crack in the prop just under the screw. Obviously the screw had been tightened too tight at the factory. I've sent an email to HH with pictures and I'm sure they'll be happy to replace the prop.
I think it's a good idea to carefully inspect everything before the first flight. What about those decals, where ya supposed to put them? |
#2 | |
I thought the same about the decals too. I think I managed to place 3 or 4 of them lol. |
I put my decals in the trash can
Blade Scout CX, MCX, MCP X & mQX Spektrum DX6i |
I would like to add if You have a crash and it happens to crash upside down check forup And down movement of the props. Treat it like The mcpx press form the top and press gear back in place. The movement of this causes the heli when giving throttle it will go in a forward movement or backwards depending on what prop it is. Just want to let you guys know.
Be blessed Isaac
Jesus Rep all over, Team Outrage USA Rep Orange Power To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. O Fusion 50, BL mcpx ultra, 700e, trex 450 pro all FBL 3g, vbar 5.1(blk), 3g, kds ebar GOD BLESS Last edited by tntburnett; 01-24-2012 at 11:56 AM.. Reason: redo |
I have had that happen once so far, had the motor pod slide off the beam twice though, first time I just new I was in trouble
#6 |
My HF Map location Join Date: Nov 2009
Location: May no longer be in Black Forest. Now in Parker CO!
Remember, RTF stands for ready to fail!
MH (Gold) MCPX BL MH (Gold) NCPX Blade NCPX Future HeliMax 1/43 Eurocopter owner! DX7. Rakon Rep. |
#7 |
#8 |
#9 |
Hardy, har, har. Most have ben descent, but theres always an exception.
Just saying its always good to check out your new toy before flying it. You never know.
#10 | |
Blade MQX, Blade MSR-X (x2), Blade 120SR, Blade MSR, Blade MCX2, Blade Scout, Night Vapor,Trojan |
#11 |
I did a check on my MQX to determine its condition, all pretty good, no cracked props. Wondered whether lubing it would make the props turn with any less force. So, After 6 flights before any lube was applied:
1) Left front - almost no resistance. 2) Right front - very slight drag 3) Right rear - same as #1 but pinion gear has slight ecentric wobble. No crashes yet, so this is as received. 4) Left rear - definate drag. No wobble. This prop always stops first. Used light oil on motor bearings, exposed end only. Same oil used on rotor bearings upper and lower. 1) Left front - better than before, barely detectable drag. 2) Right front - same as #1 3) Right rear - silky smooth 4) Left rear - better but still has drag. Flew for 8.5 minutes and charger indicated 302 ma used. This is 7-11 ma. Less than previous stock condition, I.e. No oiling by me. Have flown 10 minutes and still didn't hit 80%, though to be fair I'm not hammering it yet. I think HH did a good job on this little guy, considering how it flies and the price. Have to see how many flights we can get out of it before any motors need replaced. Have fun! PHC P_H_C MCX2,MCPX,mSR,SR,B450
So many hobbies,interests and places... so little time.... |
