| Thunder Tiger 60/70/90 Raptor 60/70/90 Helicopters |
Has anybody done flybarless on a old school 90 with the stock mechanical mixing swash. I was thinking about using a Trex 700 FBL head and a 3GX . Anyone done this conversion.
700N 3GX DFC HEAD OS91HZR HAT SB20FH2 700E 3GX TP5000 45C 700MX CCHV160 EDGE693FBL BECPRO 8V 600E PRO 3GX 450 PRO 3GX KDE BLING MCPX STOCK RAPTOR 90 3D OS91HZ HAT SB20FH2 JR8917HV AR7100R 8V GY401 TAIL 9254 5V |
Not on my Raptor 90 but on the Raptor 50.
Works like a charm and flies like a new heli so fast and stable. I did use the RJX head and the Beastx and everything worked out perfect.
Raptor 50 Titan,OS50H,DS610,BeastX FBL,AR7100R T-Rex 500ESP, ICE 75,Neu Motor,BeastX ,HS5245MG, 9257 RadikalG20, AR7200BX, DS610 Trex 550FBL, Trex 450 FBL stretched- VBar |
i've done one just 2 weeks ago on a fren's Raptor 90 with a RJX Head and BeastX...fly's like a charm as always...
Gravity Always Wins |
Not on a 90, but I just converted 2 of my Raptor 50's v2 to FBL using the TT FBL conversion kits. One has the GT-5 controller, the other a Skookum SK-720 (have a Spartan AP-2000i to try as well), both with OS max 50 SX-H hyper with Hatori SAB 50 Bobby Watts muffler and CY-600 Radix blades (i know they are not FBL blades, but did the hang method and they passed so are usable). Have only hovered the one with the Skookum so far and so far looks good. I did have to move the ball links on the servo horns in as I was getting lots of pitch and mechanically adjusted to get close to a max of 11 degrees max and used the skookum to fine tune to get the +-11 degrees.
yes it works good with the trex 700 head it fits like it was made for it. as long as the 3gx does the mixing it will work ok
raptor 90 fbl raptor 50 raptor x50 fbl raptor e620 fbl Last edited by darryl123; 05-02-2012 at 03:56 PM.. Reason: pic |
