Old 01-26-2012, 02:07 PM   #1
MrMel
V-BAR Guru
Default Logo XXtreme manual
posted online now,
http://www.mikado-heli.de/downloads/...01_0044ENG.pdf
MrMel is online now        Reply With Quote
Old 01-26-2012, 02:11 PM   #2
whytlotus
Thanks Mr Mel.
whytlotus is offline        Reply With Quote
Old 01-26-2012, 02:25 PM   #3
lunohod
• maximum rotor head rpm: 1800 per min.
• maximum pitch travel: +/- 11°
lunohod is offline        Reply With Quote
Old 01-26-2012, 05:17 PM   #4
Victor
Thanks!!!! Assembly looks pretty strait forward. Just gotta pull all of the screws out of the pre-assembled frame to locktite them.
Victor is offline        Reply With Quote
Old 01-26-2012, 06:17 PM   #5
dahld
Get an electric screwdriver with a hex driver attachment. I will attest that doing it all by hand wears you out (-:
(-: Dave
Kyle Dahl
Sponsored by:
Mikado, JR, Voltz/Thor, Scorpion, Edge Blades.
dahld is offline        Reply With Quote
Old 01-26-2012, 06:38 PM   #6
ping
I'll throw my recommendations out there for an electric screwdriver. You want something with an adjustable clutch with a very low torque setting. This is the combo I use:
http://edsracingproductsstore.com/in...&productId=162
http://www.amazon.com/Hitachi-DB3DL-.../dp/B000H2P05Q
When I first got it I set the clutch at 3-4 and finished to final tightness with my hand tools. Once you use it for awhile you learn how all the clutch settings effect the final torque. I'm at the point where I know all the settings for metal, plastic, and wood.
This setup has been one of the best investments I've made into this hobby. My hands cramp a lot during a build and the electric screwdriver really eliminates the fatigue.
Here are some alternatives if you can't find the Hitachi in stock
http://www.amazon.com/Makita-DF010DS...ef=pd_sim_hi_7
http://www.amazon.com/Milwaukee-0490...ef=pd_sim_hi_7
ping is offline        Reply With Quote
Old 01-26-2012, 10:32 PM   #7
Jays200
I've been waiting so long for this heli I don't care if my whole body cramps.
Regards, Jayson
Logo Xxtreme 800 Silverline, Pyro 800-40L, Kosmik 200A, 14S, 157 & 256 @ 8v
Logo 600SX, Silverline, Pyro 700-45L, Helijive, 12S, 272 & 256 @ 6v, 623, 105
Logo 400SE Mini Vbar, Mini Pyro 20-08, Jive 80+HV, 6S, 9660A+ 8900G @ 6v
Jays200 is offline        Reply With Quote
Old 01-27-2012, 12:10 AM   #8
trickybit
I fully dig my Milwaukee; came with two batteries. Use it a lot, both extraction (speed == 2) and assembly, for nice consistent tightness w/ no effort.
I don't trust it into plastic parts, but no worries at all into aluminum.
Logo 600: Jive, BLS, VBar "Hansen Built"
T-Rex 550E: ICE, BLS 251, VBar
Protos 500 (plastic): Jazz, Hyperion/Scorpion, VBar BLS 251
Tornado Coin-Op: Gray marble, XTremeSoft wraps
trickybit is online now        Reply With Quote
Old 01-27-2012, 12:12 AM   #9
trickybit
Ping, that Hitachi is crazy ugly! Pay extra for that.
I use maverik bits; perfect so far. Get a handle for them, and now you have a second hex driver for whatever feathering spindle you may happen to have.
Old 01-27-2012, 01:10 AM   #10
cshutchinson
Ping,
Is this the new model of the driver you have?
http://www.amazon.com/Hitachi-DB3DL2...7648144&sr=8-2
Logo 6003D 10S; PYRO 700-52; JIVE 80HV; BLS451s; BLS251; VBAR 5.2 Pro; Edge 603mm
TRex 700eV2; 700MX; JIVE 80HV HS; BLS451s / 251; VBAR 5.2 Pro; Edge 693 / 105
cshutchinson is offline        Reply With Quote
Old 01-27-2012, 07:14 AM   #11
OverTemp
So... Since the tip speed of the 813 blades at 1800 RPM is ~18% (don't know bolt spacing vs an SE) faster than the tip speed of 693s, does that mean 11 degrees on the 800 will feel like 13+ on the SE (both at 1800 RPM)?
Basing this on prop pitch speed logic.
1 - LOGO 600 stuffed with angry hornets
2 - A sad & lonely looking Rush 750 that I can't find time to finish.
3 - 7HV stuffed with over-tired honey badgers
OverTemp is offline        Reply With Quote
Old 01-27-2012, 08:01 AM   #12
dahld
I'm no aero-engineer, but I doubt it translates over very well between the two helis mentioned, just by using the relationship of tip speeds. The 813mm blades have a wider chord than the 693's, power to disc loading relationships will be different, and a "scaling effect" reality with anything that flies, is that if something is twice as large, it usually weights in at more than twice the weight.
It is my opinion that the limitations placed on the machine in the manual are there because of lawyers and liability reasons, not because the machine magically becomes unsafe if the limits are exceeded.
(-: Dave
Kyle Dahl
Sponsored by:
Old 01-27-2012, 08:28 AM   #13
Nko15
Dave, what is the tailratio on the XX and the bolt hole to bolt hole distance on the XX's tailgrips?
I do remember some people put 115 tails on the 700E in order to get right tail authority.. The XX swings even larger blades at even lower rpm.. wich means even less authority
Designing/Building the HEX Helicopters
Sponsored by Gens Ace Batteries, RCbearings.co.uk, Rapideyewear.co.uk
Nko15 is offline        Reply With Quote
Old 01-27-2012, 09:27 AM   #14
dahld
XXtreme's tail ratio is 5:1(appears to be exactly that by counting the tail's revolutions for one of the head's).
Tail blade grip bolt hole spacing is 83mm.
Uli R. was flying 130mm tails on one of his XXtremes in 2011 while testing low head speed set-ups. He said he liked it. I don't know what he runs as a general rule.
But generally speaking, we've found the 115's able to deliver all the tail authority needed.
Your comment: "I do remember some people put 115 tails on the 700E in order to get right tail authority."
All I can say is, what others do with other models with different tail designs and drive systems is of course up to them. But such actions by them on a different model and design should not immediately make you think the XXtreme's tail on 115's is lacking.
(-: Dave
Kyle Dahl
Sponsored by:
Old 01-27-2012, 09:46 AM   #15
heli21
Just for comparison, the tail blade bolt spacing on my Synergy E7 is 66mm
Rob
heli21 is offline        Reply With Quote
Old 01-27-2012, 03:07 PM   #16
Nko15
Was just thinking. if the tail speed was lower, it would get into authority problems much easier with lower rpm and 800 blades.. 5:1 sounds good, together with the big bolt spacing, it sounds great should give enough authority...
Old 01-27-2012, 05:34 PM   #17
ping
Originally Posted by cshutchinson View Post
Ping,
It is the new version, I have not personally tried it and I'm not sure what if anything they changed. Looks like they only changed the styling which would be a total downgrade in my opinion. You can still get the original at radio shack http://www.radioshack.com/product/in...uctId=11007659
Old 01-27-2012, 06:44 PM   #18
Agibbs996
So, how many hours do you think it will take to build?
Agibbs996 is offline        Reply With Quote
Old 01-27-2012, 11:04 PM   #19
okteister1
Dont like the way batteries are attached - looks like it would take forever to close 6 velcro straps. Surprised that Mikado didn"t come up with a quicker alternative.
okteister1 is offline        Reply With Quote
Old 01-27-2012, 11:20 PM   #20
trickybit
I think you buy more than one plate. Pricey but convenient, but the packs are so $$$$ you won't notice.
