Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 01-27-2012, 11:10 AM   #1
CODE3EMT
Default HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Ok she's all bulit.................... ESC mounted, 3GX mounted, Sattelite Rx mounted . I'm looking at a brand spankin new 550 and a new Spektrum DX7s, 3GX is loaded onto windows, Li-Po is charged. Now what? I'm new, at have no clue what do do now. Manual is a bit vague????????????? I'm not even sure which servo plugs into which port eg. rudder,elev,pitch, aileron. The manual shows different assignment as far as channels and radios. The 3GX program on windows seems a bit tricky, and the wire to the USB is so dam short. Any advice please
CODE3EMT is offline        Reply With Quote
Old 01-27-2012, 11:50 AM   #2
johnsandywhite
Basically it is the same to set up as the 3G. Here you go:-
Been there and done that, but NEVER stop learning
johnsandywhite is offline        Reply With Quote
Old 01-27-2012, 12:15 PM   #3
rctazz
Great Videos and they will help...But if you are new and not sure what you are doing, I would seek some "In Person" help to go over your setup and check out the usual stuff.
Not much sucks as bad as flying a new Heli's maiden flight and it crashes because of a missed or botched setup step. It has happened to most of us. Me on my 550E (4th Heli built) and somehow during setup I accidentally reversed the gyro. Took about 5 seconds before the Heli started spinning uncontrollably while still on the pad then tipped over when the tail fin caught. About an 80 dollar face palm.
Jim
Trex 250 ---- Trex 450 Pro ---- Trex550 FBL ---- Trex 700E FBL ---- Avant Aurora 90E ---- Goblin 700
Keep it off the Ground....but just barely
rctazz is offline        Reply With Quote
Old 01-27-2012, 12:22 PM   #4
mtuccio
Please make sure you disconnect the motor from the ESC or move the motor back so that it has been disengaged from the pinion before you start messing with any of the set-up with the 3GX.....
In regards to your set-up you want to hook it up as the manual shows for JR/Spektrum radios. I would also take some quality time to sit down and STUDY the 3GX section of the manual and then ask questions up here is you don't understand. If you set something wrong then this could lead to a very expensive maiden flight. Also, if you know someone with heli experience then it isn't a bad idea to reach out and get some help.....
mtuccio is offline        Reply With Quote
Old 01-27-2012, 12:44 PM   #5
CODE3EMT
THANKS FOR THE HELP GUYS.
Old 01-27-2012, 02:47 PM   #6
markleyland
Read, watch and read some more! Also good advice here about getting someone to look over it for you if you have the option. I never use the esc for setup and use a receiver pack instead, no way to accidently spool up that way.
"Sort your head out and fly with your heart"
Trex 450 SE V2: 9257 tail, Spartan Quark, HS65mg cyclic, DX7-AR7000, NEU 1107h/2y, Jazz Esc,
Trex 550 FBL: Jive 100+LV, KDE/NEU 1907H/1/N42, Vbar 5.3, Futaba BLS 251
markleyland is offline        Reply With Quote
Old 01-28-2012, 06:43 AM   #7
CyprusFlyer
All good advice, new too and did not find it that difficult after a lot of video watching, reading up etc. About the short USB link, easily fixed, just buy a standard USB extension cable from a computer shop :-)
LOGO 500SE & 600SE & 600SX
Synergy E7 -
N7 - N5C
zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzTDR + II
Alun
CyprusFlyer is offline        Reply With Quote
Old 01-29-2012, 06:37 PM   #8
billmjam
Ditch the 3GX! It's a P.O.S.! You will save yourself a whole heap of heartache! Go for a Beast X or a new AR7200BX from Spektrum! Just got mine and it is FLAWLESS!
TREX 500 DFC PRO , TREX 550E FBL V2, TREX 700E DFC, AR7200BX in all three, DX8
AMA #969521
billmjam is offline        Reply With Quote
Old 01-29-2012, 06:56 PM   #9
n6nev
I agree,, get the Beast X
"You can always tell a pilot,but not much"
Gaui X 5 Phanthom 2
n6nev is offline        Reply With Quote
Old 01-30-2012, 05:47 PM   #10
Starcruiser
VBAR
Carl
Trex 550E FS Vbar Pro 5.2- EXI-450T Mini Vbar Pro 5.2 - EXI 450T BeastX - Trex 250SE - mCPx v1 Hp05 & HP06 w/HP03t tails - AMA #952544
Starcruiser is offline        Reply With Quote
