| Scorpion ESC and Motor Support Scorpion Power Systems ESC and Motor Factory Support Forum |
#41 |
i'm building a whiplash with the scorp V 130a. i have 8717 for cycle (not HV) and a torq 9188 for the tail -- was thinking of running at 6.2v, seem like the lfe pack a few replies back would be perfect, so long as dont charge it above 6.2?
thanks for the wiring diagram as well -- i'll be running a fullsize vbar with two sats, and that really clarified the wiring for me! |
#42 |
Location: God's own county. Ay oop lad, tek care lambs ont road
Now don't quote me on this but with the Life you can set the BEC to 7.4. Although a LiFe has a nominal voltage of 6.6v for 2S, at its peak charge it is 7.4v thus it is fine to use it on 7.4v if you wish. You would be best served however ensuring the LiFe was fully charged before turning on otherwise it might draw a reasonable current through the BEC as it starts to charge.
If I am wrong on any of this, it will be a matter of minutes before someone points it out I am sure!
Rush 750, Vbar, 9188, BLS157HV, Kosmik 160, 4525 Ult Fusion 50, Vbar, 9188/80s, Helijive & Quantum 4135 motor, Mini Protos DS95s/95i, Ice Lite 50, mini v Trex 450 Pro DS95/95i, Mini V, RJX head, Ice 50 Lite, 6s 2221-2010 DX18 |
#43 |
7.4 isn't too much for my torq 9188, but seems high for my normal voltage jr 8717s... no?
#44 |
Oops sorry, I thought you were asking about the BEC voltage against the buffer pack not your 8717s. I guess 7.4 V will be too much for them. I've had a loooonnnng day
#45 |
i do have rec pack that came with my dx7 -- 1100mah 4.8 nominal nicd. its probably heavier than the life, but the voltage should be good?
#46 |
hmm. i've found other threads where people have used 8717 (not HV) with life packs with success, so i think i'll go this route. I think it will be nice to have a buffer, and an easy way to do setup without the main batt plugged in, and add some weight to the nose of my whiplash.
#47 |
I may not be understanding you correctly, but if you are going to run the bec at 5.4v or 6v you should not use a 2s LiFe as a buffer as the voltage of the pack will be higher than the bec, and could cause damage to the ESC/bec.
You will need to run a Nimh pack in this case. From what I've heard/read for bec at 6v run a 5s Nimh pack as buffer. |
#48 |
gotcha, would have to run it at 7.4 to use the life, makes sense. perhaps the nicd is the best starting point, since i have one already that isn't being used.
#49 |
This is what I use on all my heli's and can be run with bec anywhere between 5 and 6V. The pack holds 4 AAA nimh batteries and has an on/off switch right on it so its very simple and effective for buffer/emf. Just plug right into vbar/rx and no worries.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#50 |
thats pretty nice. i've ordered a switch and eneloop 6v nicads for the job already or i'd grab this one.
#51 |
I use four 6A diodes in series to lower the 2S lipo from (7.6v best store voltage ) to 4.8v and feed to the reveiver . Set up the BEC to 6.8v . Output of bec is in parallel with the output of dropped lipo output . Lipo will not be charged during bec is working since the diodes block the current . Basically , bec will take all the loading during in flight , no lipo power will be consumed . In case the bec fail , receiver voltage will be keep constant at 4.8v from the lipo .Connect one led and resistor in between the four diodes . The led will light up if bec is not working due to the 4 diodes voltage drop .Extra one diode connect the Bec output to the receiver in order to block current flow back into the bec . Total weight for the backup is about 55g. 20g for the circuit board and 30g for 35c 400mah lipo.Extra extension wire with one diode connected between bec and receiver ( 5g) .
for those pilot use hv servo you can raise the bec voltage to 8.4v and short one of the 4 diode . This will raise the backup circuit output to 5.5v (3 diode instead of 4 , 2.1 voltage drop) which can still run the hv servo . Last edited by kkkklee; 02-21-2012 at 12:27 AM.. |
#52 | |
Yeah I do suffer from an unreasonable fear of losing my legs.
KASAMA SRIMOK 90E Faifa FBL VBAR HK-4525-UE PRÔTOS 500 FBL AR7200BX CF HK-3026 PRÔTOS 500 Stretch FBL Brain CF HK-3026 Blade 400 M.I.A, mCP-X BL, MSR, Syma S006-clone |
#53 | |
V-BAR Guru
Gone fishing.. or hunting or something.. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#54 |
Oops sorry forget about my previous post - didn't read this before.
#55 |
SBEC 7.4V to Vbar
Single LiFe flight pack - I never take it off (I used to run two in parallel with no BEC)
Some notes: my servos are all Futaba BLS (352 cyclics and 256HV tail)
Disadvantages of my power system
Advantages of my power system
I've been hit in the leg once from this heli that spooled up on me (I forgot to do a rebind for the vbar/JR101 to set failsafes) so my startup sequence is probably bordering on paranoia for some. Anyway, here it is: Startup sequence
Post flight
Some photos
#56 |
Rchelijc,
Is the commander protected from reverse current flow on the BEC? If not, the esc should be armed first, then the LiFE connected. At the end of the flight, disconnect the LiFE first, then unplug the packs. This also allows you to check that the BEC output is good.
Goblin 700, TT X50e, Synergy E5-600, Fusion50, Trex 700e HeliDirect, Team iKon, GrandRC |
#57 | |
At the end of flight I always disconnect the main packs first. The reason is to minimize my time next to a fully armed heli. I've seen what happens when I was accidentally in normal mode, non-gov, throttle hold, mid-Stick. No soft start. When I let go throttle hold, it spun up so hard and fast that it wrecked the root of the blades (which was tight) and sheared the Jesus bolt clean off. Would have taken both my legs clean off had I stood nearer.
