Old 06-07-2007, 02:35 PM   #1
Big Fil
Default 450 and Real Flight
OK why does the real Trex turn so much easier in real life than in Real Fligth? I have Yogi's 450 in real flight and it seems it slides out much easier on the sim than for real. I also downloaded the 600 in preparation for the maiden of my real 600 and am wondering if it react similar.
Big Fil is offline        Reply With Quote
Old 06-07-2007, 07:27 PM   #2
oldschool269
yes there is a 600 that flys very close to the real one ..
although i went into the specs and regeared the tail , so it pyros faster much like the real trex..
Jason
oldschool269 is offline        Reply With Quote
Old 06-07-2007, 08:16 PM   #3
Big Fil
How is the turning? Funny cuz the 450 feels pretty accurate until you bank it into a turn.
Mikado Model Helicopters
Edge Blades
Old 06-07-2007, 09:08 PM   #4
fsusmithc2
Big Fil, where did you find the 450 you're using? I've tried a couple and they seem way too easy to do maneuvers than my real one. Granted, I've only been flying for about 5 months now and I'm not pushing my real one but still.
Also, whenever I start with the model, the blades aren't right and I have to edit the heli each time to select 325mm blades. Then, it goes nuts unless you're in idle 1 or 2. Normal mode just makes it freak out all over the place.
AMA 879592 - IRCHA 3241
fsusmithc2 is offline        Reply With Quote
Old 06-08-2007, 12:41 AM   #5
Big Fil
The 450 model is by someone named yogi and I believe it was at a sight called knifedge. Check out the simulator forum on this site. There's a whole thread on it.
Edge Blades
