Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Atom 6HV, 6HVU and 550 Ultimate
Atom 6HV, 6HVU and 550 Ultimate Compass Atom 6HV, 6HVU and 550 Ultimate Model Helicopter Discussion
Old 01-29-2012, 03:31 AM   #1
Magnazan
Default Compass Motor Shaft
Finished building the 6HV and took it out for it's maiden today. SOOOOO much power. Anyway started going through the usual tests and threw a flip. As the heli was inverted the head speed died like I'd gone in to normal so I hit hold and autoed, no damage love the hang time.
I got it home and pulled the motor, thinking it maybe the motor pinion, nope turns out it was the shaft in the can. I can actually pull the whole thing out!!!
Question is, can I just loctite the shaft back in to the can or is it actually faulty?
Ian
7HV ULT TracX | 550U TracX | DX9
NZ Heli thread - http://www.helifreak.com/showthread.php?t=480630
Magnazan is offline        Reply With Quote
Old 01-29-2012, 12:16 PM   #2
Larry227
I haven't had my motor apart yet but was under the impression that the shaft is a press fit in the can. If it was loose enough to come out on it's own I'm not sure I would trust Loctite to hold it unless I was desperate to fly and had no other option.
Is this a brand new motor?
Trex 700 Pro DFC - Compass 6HV - Vcontrol - Neo
#nodroneshere - 104
Larry227 is offline        Reply With Quote
Old 01-29-2012, 12:18 PM   #3
Larry227
If you don't get warranty on it you could also try this trick and see if the other end fits tighter.
#nodroneshere - 104
Old 01-29-2012, 06:06 PM   #4
snaaakeey
That should be an interference fit! If you can pull it out by hand it been manufactured wrong and you should send it back! I had to press my shaft out on a drill press! Defo wrong!
6hv (fb)
7hv
DX8
snaaakeey is offline        Reply With Quote
Old 01-31-2012, 12:35 AM   #5
Magnazan
Good to know. Now awaiting on support :/
Ian
