Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 200
Hurricane 200 Discussion and support of the Gaui Hurricane 200
Old 01-29-2012, 09:38 AM   #1
CF_Machete
Default savox sh-0262mg's as cyclic servos?
has anyone used these on their cyclic? They are .06sec, but only 1.2 kg-cm. I'm currently running Hyperion ds-09scd's that .13sec and 2 kg-cm... but the pos's keep burning out. I've changed my radio and my 3-axis gyro several times...sill with the same issue. So I'm convinced the hyperion's have to go.
fbl furion 6, fbl gaui 200 v2, FBL Stretched Align 450 pro V2, fbl t-rex 500, fbl beater 450...and some planks.
Stuff for sale
CF_Machete is offline        Reply With Quote
Old 01-29-2012, 12:10 PM   #2
clytle374
I tore the gears out of a Hyperion, but never had any other failures. Might want to check the output of your esc to be sure it isn't over 5V.
Cory
clytle374 is offline        Reply With Quote
Old 01-29-2012, 05:46 PM   #3
CF_Machete
the ds-09scd's are rated for 6 volts, which is what my bec is set for. the odd part is that this only happens after the bird has sat unused for a month or two. I think I'm switching to the savox servos.
Stuff for sale
Old 01-29-2012, 06:55 PM   #4
desertstalker
Those savox ones look like a more tail servo spec, they should make others that are slower with more torque, you could use DS410M as well, they are made by savox.
-DX8
Old 01-29-2012, 07:00 PM   #5
clytle374
Maybe I have an old sheet, but mine shows 4.8/5.5 volts.
Cory
Current sheet from Hyperion
NOTE: DS09 are optimized for max power on standard BEC ESC systems. Voltage input only 4-cell NiMH Rx pack or BEC with 4.8V~5.5V output.
Old 01-30-2012, 05:22 AM   #6
gratefulfrog
I had some hyperions and had to return them since they were defective. Doing all sorts of unexpected movements or just not moving. Hyperion Europe admitted that they had a defective bunch and refunded me.
I'm now using Savox SH-0261MG on cyclic and SH-0262MG on tail. I use the Skookum SK-360 FBL and a Futaba GY-520 servo. The whole things runs at 6V via a separate BEC since the current draw is too much for the Castle Phoenix25 builit-n BEC on 3S.
The problem with the SAVOX is the extra weight, which adds to the extra weight of the BEC and all those wires. In the end the thing flies like a dream but I only get 5m30 flight on 3S 800mAh, landing with 20-25% remaining battery.
If I were you, I would try using better servos (heat dissipation, stronger gears like metal) on the cyclic and ensuring that you have enough current capacity in your BEC. If you are using both a FBL and a separate gyro, then there's a good chance your ESC's BEC is running very hot, maybe cutting out?
Also, if you are using an FBL, then you need cyclic servos that can work hard and not over heat. Metal gears, metal casing would be best IMH...
Hope any of that helped.
Ciao,
Bob
gratefulfrog is offline        Reply With Quote
Old 01-30-2012, 07:46 AM   #7
clytle374
That is the first I've heard of problems with the Hyperion servos, even in FBL helies, seems most everyone is using them in the 200s. But I do run the metal gear version(SMD) in mine. Anyway I decided to look a little more this morning into the voltage issue and found this fresh from their website. Looks even worse than them not being 6V rated.
Maximum Input Voltage 5.5V Unloaded Voltage Max
I guess they are planning for wire/connector loss when loaded even at 5.5V. Nothing wrong with getting better servos, but no doubt this is why they are burning up.
Cory
EDIT: On the other hand I see that, unlike Hyperions, you can get replacment cases for Savox servos. Which is a real sore spot with me since I have a Hyperion with a broken case.
Old 01-30-2012, 09:38 AM   #8
DMala
Originally Posted by gratefulfrog View Post
(...) In the end the thing flies like a dream but I only get 5m30 flight on 3S 800mAh, landing with 20-25% remaining battery.(...)
That does not sound too bad at all for a 800 mAh battery, I get 6' on a 2S Hyperion 900 mAh.....
DMala is offline        Reply With Quote
Old 01-30-2012, 04:09 PM   #9
desertstalker
He is using 3S, so 50% more energy is available...
-DX8
Old 01-30-2012, 06:41 PM   #10
CF_Machete
i did a little digging and found that at 4.8volts, the jr ds285 mg's have 1.22 kg-cm of torque. the 285 mg's are recommended on 450's... so I should have plenty of torque for a 200 class cyclic...plus wicked speed.
Stuff for sale
Old 01-30-2012, 07:51 PM   #11
Ampdraw
The Inolabs are worth a look at too.
Saying that I run Hyp09's but still have the retro flybar!
Amp
Ampdraw is offline        Reply With Quote
Old 01-30-2012, 08:11 PM   #12
CF_Machete
think is, I already bought the sh-0262 mg's with out doing prior research. Impulse buy at my lhs. though the savox website has them listed for a 200-450 tail servo, i think they will have enough torque for a 200 disk. worst case scenario, I can throw them into a tiny 3d foamy and pic up an extra.
Stuff for sale
