Old 01-30-2012, 11:29 PM   #1
Zangetsu57
Default Upgrade from Alpha 400 BL motor?
Hey folks,
So I'm finally getting into some 3d and my Alpha 400 on my EXI 450 Pro just doesn't provide as much power as I'd like for tic tocs, etc. Can anyone recommend a good upgrade? I have a Proton 40A ESC from HobbyPartz.com and 25C 2200mAH Turnigy 3S lipos.
Zangetsu57 is offline        Reply With Quote
Old 01-30-2012, 11:34 PM   #2
Dylan Hudock
Im running the exceed rc helium 3700kv motor and it has plenty of power for sport flying. Im flying with gens ace 55c packs and it has and those made a big difference in the power too.
KBDD Team Pilot Trex 700l-500l-450-150, Gaui X3
Dylan Hudock is offline        Reply With Quote
Old 01-30-2012, 11:45 PM   #3
Zangetsu57
Looks like a pretty nice motor, and the warehouse is in the USA . Did yours come with screws? A reviewer indicates it uses 2.5m screws, which may be difficult to find. And is a 40A ESC enough? Either way, they are out of stock .
Old 01-31-2012, 08:56 AM   #4
satgod
2 choices for you
first you have to change to a better esc
castle ice 50
now motor
scorpion 2221-8 (about the same as a mx3500) better torque so it will do punch outs with the right pinion it turns mine at 3600-3800rmps at the head no problems at all. 3400 is really all you need, really universal motor
cost wise, a toward pro 2415-06t is a 4400kv motor for 15.00 from hk and it screams
4 x Rush 750/stretched V-bar KDE 700XF-495 HV servos Greys reactor CC 160-HV
Trex 600EFL V2 V-Bar ds610 ds650 CC bec/pro Scorpion 130a HV KDE 600XF-530
450L KDE 1750 cc50 4xDS215MG k-bar
X-8 FPV Wing, TBS Discovery FPV, TBS Caipirinha FPV
satgod is offline        Reply With Quote
Old 01-31-2012, 06:58 PM   #5
Dylan Hudock
I dont think mine came with screws but i dont remember. I had screws that fit it though. I use a 40 amp esc and it just gets a little warm so a 40 amp esc is perfect.
Old 02-02-2012, 09:51 AM   #6
falcon7a
Originally Posted by satgod View Post
2 choices for you
castle ice 50
now motor
What is wrong with the Proton ESC? I'm using it with the Align 450MX and I have a lot of power with it. The soft start works pretty well for me as well.
falcon7a is offline        Reply With Quote
Old 02-02-2012, 09:47 PM   #7
Dylan Hudock
2 choices for you
castle ice 50
now motor
Why would he have to get a better esc? I have used that esc and it worked fine!
Old 02-02-2012, 09:57 PM   #8
satgod
on 3 cell I guess you wouldnt
I fly 4 cell on my 2221-8 and like to act stupid with it which pulls more current
I also like the gov. feature in it
to each his or her own
Old 02-03-2012, 02:50 AM   #9
Zangetsu57
My Turnigy 3S 2200mAH 25C packs come down a little warm (not hot) with the alpha 400. Is it likely that I'll need to upgrade to higher current packs to take advantage of a better motor and avoid safety issues? I selected these packs because they can supply up to 55A (25C*2.2A = 55A), which provides a 15A margin for the 40A ESC. Perhaps it isn't this simple?
Old 02-09-2012, 01:29 AM   #10
Zangetsu57
So it looks like HobbyPartz is still OOS on this motor: http://www.hobbypartz.com/86ma78-2220-3700kv.html
I'm considering Turnigy as I don't want to spend a ton of $$. I've heard the Turnigy Typhoon 2215H and 2218H models are good, the latter being a bit more powerful. Does anyone have any comments about these motors?
