| 450 PRO Class Electric Helicopters 450 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Powered up my 450 pro Futaba 6008 receiver,DS410m servos,DS520 tail servo stock esc blx35 and I noticed that the servos chattered and stopped working looking at the receiver I could see that the light on rec was changing from red to green (blinking) so I disconnected the servos and plugged in only the esc and the receiver light became solid untill I plugged in servos and then it started blinking.I thought it was the esc so I plugged in a old Eflite 40 amp esc and it did the same thing,so I pulgged in a sanyo 4.8v 600 mah flight pack in and it got rock solid and the servos worked normally changed back to either esc and light started blinking and the servos were erratic.Help!
sounds like your plugging the esc in backward
it will power up but everything will be silly and if left you will eventually burn up the receiver after a little time you'll notice the receiver getting warm probably make sure your pluging in the esc or bec in the correct direction if you are then it is the esc/bec that is bad
Trex 600EFL Pro V2 V-Bar ds610 ds650 cc pro bec Scorpion 130a HV KDE 600XF-530 450pro 1860kv(6s) cc50 (4 DS215MG) 10t pinion, Tarot DFC, Ikon TBS Discovery (Quad), naza-gps, 900mhz fpv, gopro2, ET OSD pro, D/L UHF X-8 Wing , D/L UHF Full fpv package |
Sense the orignal post I changed to another receiver 6008 also and it acted the same way so I can rule out the receiver and think about the current drain the servos is putting on the esc,I connected 4 DS5065"s to the receiver same esc and it is rock solid .
Have you checked if the servos move freely?
No,I haven't checked that but I would plug in one servo check for blinking disconnect it and move to another and when I plugged in any one sevo it would start to blink but not with the Hitec servos,this heli was flying great last time out !
#6 |
sounds like you have a dead servo there...plug one servo in at a time untill the dead one can be found
i also had this with 410m servos before...no crash, it just stopped working and caused all other servos to glitch. chris
trex 450 pro-fbl-scorpion 2221-8-custom motor mount-beastx-tarot head-beam e4 swash trex 550e-castle 100 ice-bec pro-alloy tail control arm- 550mm blades-beastx-compass 6hv head-2mm side frames futaba T8FG--R606FS/R617FS |
#7 | |
Is the ESC getting hot when you do this? |
#8 |
When I plug in any of the individual servos in it causes the led to blink like it has lost its signal this is one at a time, and with any one single servo plugged in and it don't matter which one it is ?
#9 |
I would temporarily use my known good bench BEC.
HK Best Of Custom 450s & 500 Build Different! |
#10 |
In the morning I'll take the esc off my 500 and check it out and hopefully it will confirm the esc is where the problem is . Thanks for the help!
#11 |
hmm..it cant be all the servos...try the rx swap...
chris
#12 |
Found the cause it was like chrismechanic had suggested had a bad cyclic servo though would change to hitec 5065mg's I have 3 of those would that be a good swap?
