Old 03-29-2012, 01:03 PM   #381
Chep
Originally Posted by Mojappa View Post
I don't get the idea of taking many tiny steps towards a bigger heli.
Tell me about it, buddy. I went from a 120 SR to a T500 EFL. Talk about a steep learning curve
Chep is offline        Reply With Quote
Old 03-29-2012, 01:14 PM   #382
jaydekay
Originally Posted by lkagan View Post
I've used these CF blades on my Blade SR in the past with success. They're really good quality. They just came back in stock today. They are 1cm longer than the stock blades. I'd recommend them. They're from a US store and they ship fast, HeliDirect.
- Larry
Just a tip -
FBL blades are different than FB blades and they can make a huge difference. Usually when you put FB blades on a FBL heli you're heli will get really pitchy, and it will bite a lot harder on the collective, to the point where you just blow on the collective and it will pop.
FBL blades have a CoG that is closer to the tip of the blade. And, chord-wise the CoG is closer to the leading edge.
This makes a difference in how the blades feather through the air as well as on how stable the heli is (from a gyroscopic-effect standpoint)
If you look closely, you'll see that the part numbers for the SR blades (FB) and the 300 X (FBL) blades are different, even though they look similar at a glance.
jaydekay is offline        Reply With Quote
Old 03-29-2012, 01:30 PM   #383
mahbouni
Originally Posted by jaydekay View Post
Just a tip -
Yes I have Thunder Power 325 FB blades on my T-Rex 450 Pro, using Vbar 5.24. Its very pitchy around centre. Flies great in the air - piro hurricanes and rainbows are really locked in - but landing is an effort. I have normal mode at only 50% throttle to bring it down gently or I just hit the throttle hold before I land.
Logo 700 Synergy E7 Logo 600 Logo 500 Protos 500 Mini Protos
mahbouni is online now        Reply With Quote
Old 03-29-2012, 01:35 PM   #384
lkagan
Just a tip -
I read about these differences and most people report on this forum and RCG that they can't tell any difference. I can't personally speak from experience because I haven't tried it yet. That being said, the HeliDirect blades are 10mm longer each and have a shorter chord wich I'm guessing would lead to less of that pitchiness by having a smaller facing area on the angle of attack and a further out CG. I sent in a question to the Horizon podcast about the difference between the two blades (300x and SR) and John Redman couldn't answer but he said he'll find out and answer on next week's podcast.
I personally, just feel more comfortable using the FBL blades that were made for that heli, especially since there's no difference in visibility in the air. I just spent a few hundred on a heli, I'm not complaining about spending $30 more for good blades meant specifically for this bird. It's nice to know there's options though.
- Larry
lkagan is offline        Reply With Quote
Old 03-29-2012, 03:48 PM   #385
jaydekay
I read about these differences and most people report on this forum and RCG that they can't tell any difference....
- Larry
I can tell you from first hand experience that it makes a * big * difference on the 450 with the Microbeast.
Mahbouni has the same experience with his TP's which are really nice $40 FB blades, and he's using the Vbar.
This isn't a marketing scheme or anything silly like that. They make FBL blades for a reason.
It's not really that you need to use the blades that are specific to a certain model (although that's a safe bet). But you should definitely try to use the right type of blade for the right type of stabilization system (FB or FBL).
PS - I fly mostly FB blades on my FBL 450, but thats only because I have 16 sets of CF FB blades that I need to burn through - so far I'm on set #2. I bought them before I went FBL.
Old 03-29-2012, 08:39 PM   #386
Andrew73
I don't get the idea of taking many tiny steps towards a bigger heli. Even a 120 is gonna be likely to break things in a crash but won't be much more useful of a training tool than the mCP. Why not just practice on a sim, then take it to an mCP and when it's effortless on the mCP do it with the 300X? That way you can still fly outside your skill set with the mCp consequence free and have a better performing bird to really learn to fly within your abilities with.
I've already got a modded 400 but I'm not interested in chucking it about the sky because it's too intimidating and too much effort to set up and fix. I end up cruising around with it and sighing with relief when it touches down in one piece, and that's after a year of flying and countless hours on the sim. The mcpx is loads more fun because I can throw it about in all orientations and not worry when it piles into the ground; I had it inverted within weeks it's so easy to fly.
A brushless 120CPX would be a step up which could do all the 3D I'd ever want and it would be lighter and more robust than a 300, which I expect will be just as fragile as a 450 but more fiddly to work on. I do like the spec of the 300 and the videos look amazing, I'm sure I would want one if I didn't already have the 400 but I've realised the micro-birds are more fun for me. If Blade don't come up with something for beginners I'll end up with a V120D02S but I don't really want to waste money on another TX.
I just hope they don't waste their time with a fixed-pitch 120X, that would be such a disappointment.
Andrew73 is offline        Reply With Quote
Old 03-31-2012, 12:46 PM   #387
photocycler
I have taken interest in this heli, I am looking for something to fly in small areas, already love my beastx on my 500 and parts are cheap for this.
I am considering this as a replacement for my mcpx, yes cant be flown indoors like a mcpx but looks like a good yard flyer.
PRÔTOS 500 CF - BeastX
MCPX
photocycler is offline        Reply With Quote
Old 04-01-2012, 12:15 AM   #388
Daniel880516
I think im gonna retire my x2, i have 10 1300 lipos, scorpion 3400kv, mks ds95i, waiting for it!
Team RotorQuest / SAB Heli Canada
Goblin 770
Xxtreme 800, Xxtreme 700
DX18
Daniel880516 is offline        Reply With Quote
Old 04-01-2012, 05:32 AM   #389
R3L72
Smile Count-Down Continues...
It's seriously looking like the 300X will become a very popular Heli!
For the Horizon Hobby Blade Development folks, I'm hoping they could get a jump on the aftermarket companies and seriously consider releasing some different colored canopies, blades, and fin's to allow a greater range of personalization.
My 450X will pretty much remain stock in looks and my 3 mCPX's will still be flown, but with the 300X, I plan to log some numerous flights ... I love the smaller Heli's!
However, I do plan to shelf most of my Walkera fleet though if this 300X is everything I'm hoping it to be!
CY NextD Rave 3D, MSH Mini Prôtos (6S) Stretch, Prôtos 500 Stretched
Blade 450X, 300X, 130X, mCPX, Nano, DX6i, DX8
Align Trex 450 V2 Pro DFC, & too many others to list...
...living the Hobby 4+ minutes at a time
Last edited by R3L72; 04-01-2012 at 05:35 AM.. Reason: Increase the size of the font.
R3L72 is offline        Reply With Quote
Old 04-02-2012, 01:09 PM   #390
glarepro
Do you really anticipate the new BLADE 300X to be a better performer than the X2?
The only thing I can say for certain at this point is that the BLADE has a shorter main-rotor diameter, which says it should be a quicker turning heli. If the BLADE is heavier than the GAUI then that would somewhat negate the effects of the smaller rotorblade diameter. I doubt that the BLADE will be heavier becuase it uses plastic in alot of the places where the GAUI uses aluminum. The more I type the more I can see the new BLADE 300X possibly besting the GAUI X2. No way to say for certain until I fly them back to back. How much longer do we have to wait?
glarepro is offline        Reply With Quote
Old 04-02-2012, 01:20 PM   #391
lkagan
The unofficial word is the 16th of this month is when they hit Horizon for shipping out. Kinda cool that Blade is actually being compared to the likes of Align, GAUI, etc... It doesn't matter if it's better or not, but the comparisons are being made and they never really were before. Congrats Horizon / E-flite / Blade, you've come a looooooong way since the Blade CP.
- Larry
Old 04-02-2012, 03:44 PM   #392
Daniel880516
I have only had belt issues, and Gaui never responded to cure the problem instead some Helifreaks from Europe had to machine some custom pulley to cure the problem a bit, but still will slip during tic tocs and hard pitch pumps, ball links from the blade grip will bent after a crash, and you have to buy brand new blade grips just because of that, and the screw that holds the head block to the main shaft is ridiculously small (like the mcpx screw that holds the main board to the frame) that I had to buy a head block after my first crash because it snapped inside, other than that it's a super powerful and smooth excellent heli. They are focusing more on their bigger guys, you can see in the Gaui 255 forum, most likely you won't see any reps responding to issues compared to the X5 and X7 forum, and that's what makes me think twice, having 10 almost brand new 1300 3s sitting around, while I need to send my tail case to a guy from Netherlands to put a custom pulley for better meshing. I kinda wanna give up to be honest, plus parts have to be ordered online etc. etc. So far, having my 450x for 2 weeks, I'm very confident with the design, and seems like the 300x is sharing a lot of the design from the 450x, at least there is no major flaw that will cause any crashes like the X2, 2 crashes I had are from tic tocs, and I have a footage of it.
Goblin 770
DX18
Old 04-02-2012, 07:56 PM   #393
jrod155
all of the above is why i sold my X2, after the 3rd crash from my belt slipping even with the new pulleys, i was done.
I was waiting for the 300, but couldn't wait and ended up with the 450X, i'm loving it.
Compass 7HV, El Brute, Ice2 120HV, TracX fbl
Compass Atom 500, Ice 100, TracX fbl
TX: Futaba 7C w/ Fr-Sky DHT, Soon to be Taranis
Old Models: X2, X5, TREX(250, 450, 600ESP), WARP 360, 6HV, 450X, bl CO5M MCPX, Genius CP
jrod155 is offline        Reply With Quote
Old 04-02-2012, 08:14 PM   #394
Daniel880516
Me too, I have the 450x already but still want the 300 because of all the batteries I have, plus I kinda want every size of heli in my collection lol, now where is the 120cpx!
Goblin 770
DX18
Old 07-03-2012, 07:14 AM   #395
thomascoleman
can you do a dead side on shot the 2nd picture is slightly raised.
Spektrum DX18 | T-Rex 500 DFC AR7200BX | T-Rex 450 Pro DFC AR7200BX 3S | T-Rex 450 Pro DFC AR7200BX 6S | Align 250 DFC 3GX | Goblin 630 AR7200BX
thomascoleman is offline        Reply With Quote
