Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X7
X7 Discussion and support of the Gaui X7
Old 02-07-2012, 02:47 PM   #41
akschu
I'm finalizing my order now. Right now I have the 4035-500 motor but I have time to switch it to the 4035-560 if I act today. Should I do that? I see that it's rated for more watts and amps, but it seems like it would force me to run at least 2200 rpm on the head without really socking it to my esc.
schu
akschu is offline        Reply With Quote
Old 02-07-2012, 03:06 PM   #42
Rob Cherry
schu
What was your target RPM, and which controller will you have?
If using a CC, set rpm will be around 2126 with 10T/560kv, other ESC's will operate more efficiently at around 2250rpm, but you could certainly run 2000 without "socking it" to your esc.
The 500kv with CC is around 1900rpm, jive/vbar around 2000rpm.
E7 | E5S | E5
Team Synergy | Gens Ace | Scorpion Motors | Progressive RC | Anything Heli
Rob Cherry is online now        Reply With Quote
Old 02-07-2012, 04:39 PM   #43
akschu
I'm getting the scorpion commander 5 130A.
Sounds like I should get a 560 then.
schu
Old 02-07-2012, 05:19 PM   #44
Chris Sexton
schu
Or an 11t pinion. That's what I did. Gives the gov some overhead.
Team Synergy/Team Scorpion
Chris Sexton is offline        Reply With Quote
Old 02-07-2012, 06:00 PM   #45
torana74
Originally Posted by akamullen View Post
Wow, Matt you are right, I just got the X7 Pinions in and they are something to behold. HUGE! Bigger than I thought they would be.. makes the 700E pinions look like 500E pinions. Should not be stripping with these babies..
HUGE.
I put it against a 14mm 3/8 drive snapon socket. Now need the rest of it .
Sent from my HTC Legend using Tapatalk
GAUI X7, GAUI X5 all vbar.TT 12S Hurricane 550 beastx
GAUI
Field Rep, Team Empire Hobby
torana74 is offline        Reply With Quote
Old 02-07-2012, 10:01 PM   #46
Rob Cherry
Originally Posted by torana74 View Post
HUGE.
Attachment 287377
Attachment 287378
Wow! that thing could be made of cheap plastic and still take the loads. Damn that's one big pinion.
E7 | E5S | E5
Old 02-08-2012, 04:24 AM   #47
mahbouni
Great build thread Matt. What is your all up weight with battery?
Logo 700 Synergy E7 Logo 600 Logo 500 Protos 500 Mini Protos
mahbouni is offline        Reply With Quote
Old 02-08-2012, 06:10 AM   #48
Matt Nasca
Thanks! 12.2 lbs
GAUI X7 - GAUI X5 - GAUI NX4 - GAUI X4 II - GAUI X2 - All on VBar 5.3 Pro
GAUI USA / Scorpion Motors & ESC / Scorpion Competition Packs 65C+ / Spin Blades / YS Engines / VP PowerMaster
Matt Nasca is online now        Reply With Quote
Old 02-08-2012, 09:10 PM   #49
Matt Nasca
Default First Post Updated
Hey guys I've finished the wiring and updated the first post. Sorry it took so long I've been busy at work! Feel free to ask any questions, I'll do my best to answer them ASAP. I can also to specific pictures if you have any requests.
Old 02-09-2012, 04:38 AM   #50
torana74
Awesome, super informative build Matt and super neat heli
Very very very nice
Can't wait to see the flight vids
Vas
GAUI
Old 02-10-2012, 09:58 AM   #51
Matt Nasca
Default First Flights
Very very very nice
Vas
Thanks Vas!!
I was able to get some flights yesterday on the X7! I can officially confirm that the "X5 Grin" carries over and can now be called the "X7 Grin"!
The X7 minimally configured with VBar+ Spektrum satellites and Scorpion ESC/BEC and 5100 mAh 65C packs weighs in at only 12.2 lbs. It feels super light in the air. Flips and rolls are crisp, precise and axial. The collective response is smooth and linear feeling with plenty of stopping/starting power!! The whole helicopter is smooth and vibration free!
The X7 hangs in the air well and you don't have to force it to do anything. The low head gives it a compact but large feel and the long tail is a great visual cue.
In running the VBar governor with the Scorpion ESC, a headspeed of 2250-2300 feels incredibly powerful! I did try a headspeed of 2450 and the X7 really has presence there. Quickly moving the disk off hover plane results in a deep thump you can feel in your chest! It's so cool! I flew mostly at around 2300ish and with the excellent performance of the Scorpion/ VBar governor, it was plenty of power and very fun to fly!
The tail held well with 95mm blades. I think if I stay at 2300, I may go up to 105mm tails and see what that does.
I'm very excited to fly more and will post some video as soon as the the weather cooperates or I'm able to find a camera person who doesn't mind freezing their butt off for 5 minutes.
Old 02-10-2012, 12:07 PM   #52
Rob Cherry
+1 Awesome report Matt. I'll have mine on vbar gov, and roughly same RPM, should be a blast! Starting my build right now...
E7 | E5S | E5
Old 02-15-2012, 10:05 PM   #53
Matt Nasca
Here's a Fromeco DC-UP MarkII to take a little load off the BEC. It just plugs into any open spot on the VBar power bus. It takes about 10 seconds for the capacitors to drain just sitting idle. This would not be a good choice as a backup power source, only to ease the load of the BEC by helping with back EMF and current spikes.
I'm also going to try a 1300 mAh 2S LiFe buffer pack. This will plug into any open spot on the VBar power bus as well. This would be a good choice as a backup power source and to ease the load of the BEC by helping with back EMF and current spikes.
When I get the battery in I'll post pictures and a review. Also note that you would one of the two choices and not both together.
Old 02-16-2012, 03:54 PM   #54
Jamesppp
And you are using the built in Scorpion BEC? I think I remember reading that.
Very impressive machine.
Do you fly your Trex 700's at 2300 rpm's too?
Compass7HV,Sk720HeliJive120HV Pyro 700 52L allHV
Outrage 550: Scorpion 4020-1390,CC125A ESC,WR ESC
Logo 5003D Scorpion Sk720 4020-1100, Blade130X MCPX
TT E-620 SE x 2: Scorpion 4025-740 CCHV85 ,770/8900
Jamesppp is offline        Reply With Quote
Old 03-02-2012, 10:44 AM   #55
Dragonfly7775
Hi there 1st test flight with my x7
http://youtu.be/94SmJEDldUQ
Dragonfly7775 is offline        Reply With Quote
Old 03-02-2012, 12:13 PM   #56
Matt Nasca
Ya dude, the X7 in nice!
Yes, using the built-in Scorpion BEC and it's been working well. I actually settled on a buffer pack, 2S LiFe 1100mAh. The DC-Up worked great as well but I wanted to backup in case of a power loss.
Yes, I flew my T700E at 2300-2350.
Old 03-05-2012, 08:39 PM   #57
Rob43
FWIW, I too am running a Fromeco DCUP like yours. I am running Kontronik 120HV in my Compass 7HV with Vbar on a pair of Spektrum sats. I felt the Fromeco is some simple insurance against brown out. I have also corresponded with others who have had enough juice to land upon power failure just from the capacitor bank in the Fromeco.
= R
b43 =
Team Compass Support
Rob43 is offline        Reply With Quote
Old 03-14-2012, 03:27 PM   #58
Matt Nasca
Default Notice from GAUI
This was posted on Gaui's website in February.
Note:
In order to improve the convenience for assembling the main rotor head, the thrust bearing cap (with bigger inner race) is preassembled into the main blade grip. Please assemble the thrust bearing as illustrated in the manual (P. 24).
PS:
If the thrust bearing of main blade grip you got is not preassembled, please make sure the thrust bearing cap must be driven in parallelly into the main blade grip.
Old 03-14-2012, 09:09 PM   #59
irishmatt18
Cap???
Im looking at the manual and see nothing about a cap.
irishmatt18 is online now        Reply With Quote
Old 03-14-2012, 09:32 PM   #60
vr360
Originally Posted by irishmatt18 View Post
Cap???
They are referring to the inner thrust bearing race. It has a OD of 7.98mm, the outer race OD is actually 7.68mm, the inner race is actually a "press fit"and does not simply drop in.
Assembly your thrust bearing set, Inner race, middle race, outer race, drop into the grip, and use a socket or large allen key to press into place evenly. Use a flashlight to check flushness against the inner seating of the grip housing. Failure to do so will result in serious issues down the road.
vr360 is offline        Reply With Quote
