| X7 Discussion and support of the Gaui X7 |
#41 |
Its a HKIII-4035-500KV (with a 110mm shaft GAUI part# 217351) I swapped my stock HKIII 500kv shaft out with the 110mm gaui one, took all but 10 minutes.
AnythingHeli.com OWNER/ TEAM PILOT GAUI X5 / X7 * GOBLIN 500/630/770 * TREX 450DFC @ 6S * Swinging EDGE & SAB Blades * Microbeast/IKON * Castle ESC's on all * Beating on all To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#42 |
Very simple to do, even easier if you use a drill press. Took me about that long. Just make sure you have the flat spots on the shaft aligned before you press it or you may be pulling it back out again.
#43 |
Flight Style: Very bad 3D'ish and big air sports flying
FBL System: mini V Bar Motor: Gaui GUEC GM-350S Pinion: 11 or 12 not sure Target Headspeed(s): 1800/1900/2100 ESC: CC Ice2 120HV Governor: as above BEC: CC BEC Pro RX Pack: nil Cyclic Servos: Align DS610 Tail Servo: Align DS650 Main Blades: Gryphon GMB-700NX Tail Blades: Rail 106mm Lipos: Optipower 5000s
Goblin 700, Gaui X7, 600EFL, DX8 |
#44 |
I see lots of people are using CC BEC Pro. On another forum there are a couple of people ranting on about wires that come loose and cause crashes with that BEC. Anyone heard of it happening, or is it just an isolated incident, or perhaps only a problem with nitro vibrations?
#45 |
I have had bec pros on 10 or more birds. Never a problem. At least not that problem. I switched my setup on the x7 because of the savox servo issues. That is simply a amperage issue.
Team Synergy/Team Scorpion |
#46 |
X7
Flight Style: i just hover it and smile FBL System: Futaba CGY750 Motor: Xera 4035-400 Pinion: 12T Target Headspeed(s): 1800-1950 ESC: YGE120HV Governor: CGY750 E-gov RX Pack: Gens Ace 2200 30c Cyclic Servos: Futaba BLS156HV Tail Servo:Outrage Futaba BLS256HV Main Blades: Edge 693 / CYB 710 Tail Blades: KBDD Extreme 104mm
Gaui X7 MSH Brain YGE160HV Xera4035-480 X475 FES MSH Brain YGE120 Xera4020 Gaui X5 MSH Brain YGE90HV Xera 4025 Gaui X6 vbar silver 5.3 YGE120HV 700mx ElektroRC.com field rep (YGE, MSH, LAHeli) Last edited by joe1l; 04-11-2012 at 09:01 PM.. |
#47 | |
#48 |
I have been using my KBDD extremes on this heli for a couple weeks and they are actually working quite well and move perfect inside the grips. I have edge and rotor techs on my other helis and think they work great.....except when i take off in grass...which is primarily why i went with the KBDD's on my X7. In my part of NJ the ground is full of rock. I broke 3 windows on my house just by mowing the lawn, the first year I owned house. I can go through a set of CF edge tail blades in 2 weeks if i'm not careful. The plastic KBDD have been a life saver.
Gaui X7 MSH Brain YGE160HV Xera4035-480 X475 FES MSH Brain YGE120 Xera4020 Gaui X5 MSH Brain YGE90HV Xera 4025 Gaui X6 vbar silver 5.3 YGE120HV 700mx ElektroRC.com field rep (YGE, MSH, LAHeli) |
#49 | |
So far I have been very pleased with KBDD, I'll probably be ordering more soon, just in case...
AMA 988334 Walkera- Genius BL, 4g6, 4g6s, v120d02 2s, v450d01 TA Trex- 250 Mikado fbl conversion rx2702v, clone 500 fbl rx2702v X7 Edge BeastX Savox Scorpion CC Ice2 HV120 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#50 |
Mine has changed. Thought I would update it.
X7 Flight Style: Sport Learning mild 3D FBL System: Mini VBar Blue Line w/ Pro 5.2 Motor: Scorpion HKIII-4035-500 w/ XL Shaft Pinion: 11T Target Headspeed(s): 2200 ESC: Scorpion Commander V 130A SBEC Governor: VBar BEC: Scorpion SBEC with DCUP in parallel RX Pack: None Cyclic Servos: Outrage BL 9180 @ 8.4v Tail Servo: Savox SB-2272SG @ 8.4v Main Blades: Rail 696 Tail Blades: Rail 106 Lipos: Hyperion VX G3 35C 4200mAh (12s) Sent from my iPhone using Tapatalk
#51 |
Flight Style: Big Air/3D
FBL System: Silverline Fullsize V Bar 5.2 Motor: Gaui GUEC GM-350S Pinion: 10T Target Headspeeds: 1900/2150 ESC: Power Jive 120 Governor: Jive BEC: Undecided RX Pack: 2S 2100mah Cyclic Servos: JR DS8917 Tail Servo: Futaba BLS256HV Main Blades: Edge SE 693mm Tail Blades: Rotortech 105mm Lipos: TP G6 45C 5000 Last edited by IndividualWon; 06-13-2012 at 09:19 AM.. Reason: Update |
#52 |
Update:
Flight Style: 3D FBL System: Mikado V-bar 5.2pro Motor: Scorpion HK-4530 PowerDekker - 500KV Pinion: 10T Target Headspeed(s): 1750 - 1850 - 2050 ESC: YGE 160 HV Governor: V-Bar Governor BEC: Western Robotics Hercules RX Pack: None Cyclic Servos: Futaba BLS 255HV @ 8.4v Tail Servo: Futaba BLS 256HV @ 8.4v Main Blades: Radix Standard 710mm Tail Blades: Radix 105mm Lipos: Gens Ace 5300 30C
GAUI X7: PowerDekker 4530, JR DS8717HV, MKS HBL980, 12s, Vbar 5.3+ YGE160HV, DX18 DSMX || HJK LP1.1 HobbyManiac Teampilot |
#53 |
AndrewAZ Clone Account
Flight Style: Hard 3d , "smooth smack"
FBL System: Full Size Vbar 5.2.5 Pro Motor: Scorpion HKIII-4035-530kv Pinion: 11T Target Headspeed(s): 1850, 2100, 2250 ESC: Scorpion Commander V 130A SBEC Governor: VBar BEC: Castle Creations BEC Pro V3 RX Pack: Cyclic Servos: Outrage BL 9180 @ 8.4v Tail Servo: Outrage BL9188 @ 8.4v Main Blades: Rail 696 Tail Blades: Edge 105SE Lipos: Thunder Power 65c 5000mah 6s X2 |
#54 |
Update:
X7 Flight Style: sport, entry 3d FBL System: beastX Motor: Scorpion HKIII 4035-500 Pinion: 10 Target Headspeed(s): 1800, 1900, 2000 ESC: CC ICE2 120HV Governor: CC BEC: CC BEC PRO RX Pack: none Cyclic Servos: Savox 1258 TG Tail Servo: Savox 1290 MG Main Blades: Edge 693 Tail Blades: KBDD Lipos: Turnigy 5000
#55 |
X7
Flight Style: Sport and some 3d like tic tocs and rainbows FBL System: V-bar silverline Motor: Scorpion/ GAUI GM-350S, 500 kV Blushless motor Pinion: 10T (Ø 6mm) Target Headspeed(s): ??? ESC: Kontronic Helijive 120 HV Governor: Kontronic governor BEC: Kontronic.. RX Pack: - Cyclic Servos: Futaba BLS 451 Tail Servo: Futaba BLS 251 Main Blades: Edge 693 mm Second Edition Tail Blades: Rotortech 105 mm Lipos: Gen's ace 5300 mAh |
#56 |
still trying to deside what esc to buy for my future gaui x7. What i would like to know is how much of the CC120HV burned and How much of the YGE 120/ 160HV's burned and also how much scorpion 130A's in this thread....
#57 |
They all have failures, there are more cc ice owners out there so you hear more of those going up in flames. There is a data sheet somewhere with all the esc's and failures... Maybe in the cc forum.
I have the cc ice 120 and so far I have been very happy with it.
#58 |
WOW! After reading all the pilots setups, I think I may have went wrong with mine
Rumors are started by haters, spread by fools and accepted by idiots. |
#59 |
So what IS your set up?
#60 |
Flight Style: Not even good enough to call it a style
FBL System: Sk540 Motor: Scorpion HKIII 4035-500 Pinion: 10 or 11 Target Headspeed(s): At least 2000 ESC: HW 120HV Governor: ....... BEC: CC BEC PRO RX Pack: 2s 2400 Cyclic Servos: DS610 Tail Servo: DS650 Main Blades: Edge 693 Tail Blades: Edge 105 I think i went wrong with the servo's and the esc. I see alot of pilots with 130hv or more. I see a couple with 120hv's. I'm not a good enough pilot to notice the difference in the ds610's and the HV servo's that are out, but in comparison, they seem to be a little weak.
