| Compass Model Helicopters Compass Model Helicopter Discussion |
#21 |
SAR,
"I wonder if new Spektrum/combo the same Spektrum receivers are usually pretty snug...." It is not much of any different, maybe a bit tighter (still taping them in).
KBDD-Team Pilot Team Compass / ProStar Hobby Gens Ace Field Representative Warp 360, 7HV,Knight Pro,Knight 3D, Atom 500, Odin II, 6HV, 3D Plus, Knight 50 |
#22 |
Yours were snug? Mine were loose physically, but fine electrically.
Scott
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Spartan Vortex VX1 Inside Team A Main Hobbies/ProTek Field Rep ):> |
#23 |
"Yours were snug? Mine were loose physically, but fine electrically. "
Yes, but only a little bit, on the one I just installed. I noticed the fit of the plug varied with the manufacturer of the plug. I have one Futaba, with the extra projection trimmed off, that was the tightest, three Align (Savox) servo plugs (probably the least tight), one from the HobbyWing ESC and and two from the WR BEC (in between, as I recall).
#24 |
I use hot glue typically, but just sitting here wondering if there is some sort of mechanical method such as a rubber band or even some giant shrink tube.
of course you can't beat the East Tibetan Mountain Yak pooh/urine combo... hard to get, but once it sets that stuff wont come loose!!!
Team "Wife" sponsored pilot... Thanks Baby!!! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. AMA# 977810 |
#25 |
I've had 3 crashes now from plugs popping out in flight. Only one of them ended in minimal damage, the other two were doozies.
I forgot to put some on my 5203 and that roasted my motor (connector popped out at full throttle on a full tank in my Knight, couldn't stop it or shut it off). Needless to say, I'm a bit paranoid without flying with some kind of extra securing measures on my wires. I start by having them with as little stress on the wires as possible and having the connectors going down into the device as opposed to coming up from the bottom (wherever possible). I also try to keep wires bunched up together because as a group, they tend not to move much. I've used tape with a lot of good success and I've also used some clear silicone sealant, but that tends to leave a lot of chunks on the connectors when you go to get them off. Granted, the wires will pretty much never pop out of the slot, but it gets to be a hassle if you find that you're moving the electronics a lot. Hot glue works really well too, but I don't like messing with the gun (warm-up times, the mess, one more piece of equipment to maintain or worry about. Tube of glue or roll of tape is a lot more convenient). Each has their upsides and downsides, but tape seems to be the easiest. i'm just not as confident with it as the adhesives.
Tim - Atom 500, 6HV, 3D+, eAurora KBDD TEAM PILOT Compass support/Nankin Hobby.com --Si vis pacem, para bellum-- |
#26 | |
Sent from my DROID3 using Tapatalk
"It's not the crash so much as the sudden stop" Alees Rush 750, Compass 7HV, Compass 6HV, TRex450Pro, bunch of other junk in boxes ... |
#27 |
Oh, yeah... Spektrum receivers? Very tight.. the AR7200BX, not so much. There are no guides in the AR7200BX like there are in standard Spektrum receivers, so I think that translates to what I experienced.
Richard, you're right. It does vary from connector to connector. Electrically, they make good connections but physically, they vary. The connectors used on the standard microbeast are all tight, though (I checked). Interesting stuff..at least to me, anyway. Scott
#28 |
3M 4010 is clear, 4011 is gray. They are said to be identical but I have both and think the sponginess is a bit greater with the clear (could be psychological/confirmation bias). The number is not on the front of the package, it's on the back above the barcode "CAT 4010"
Are wires coming out more of an issue on larger helicopters? I've never had an issue with the small ones. I had not planned on using anything on my 6HV but now you guys have got me paranoid.
Compass Atom 6HV, Torq Servos, BeastX TREX 450 Pro 6S, Scorpion 2010, C.C. ICE 50, MKS DS95, JR 3500G, BeastX. TREX 250, ZYX FBL/ mcpx V1/ Nano cpx DX 8 |
#29 | |
Not seeing anywheres on the back designator etc.... oh well.... LOTS of Spanish though.... Ya I never worried about it with my 450 either still learning a whole bunch about these larger helicopters. Compass boards great place to learn lots of pros here know what they are talking about......
#30 |
Glue gun, tape… tape, glue gun…
Soon as I finish makin this manicotti must decide… Sent from my DROID3 using Tapatalk
#31 |
Pictures of my gooped Bx and Recv. Not as neat as most of your guys, but still works well (I crash test mine more than yours
). You can see that I had a plug in the throttle channel on the receiver, but simply peeled it back and removed it without impacting the others.
Compass 6hv FBL-BeastX; Compass Atom 500 FBL-SK720 ; Compass Atom 500 FBL-BX; Blade 130x; Spektrum DX8 |
#32 |
Don't get to see this too much round here…
#33 |
Finally decided I must get off this "There may be other unexplainined elecronic failures" fence… I have not flown my beloved 6HV IN 4 months since it decided to crash itself…
I have gone through everything 25 times at least 25 full power bench runs everything looks perfect… Still not sure what caused it to go out of control but leaning mostly at this point to my ineptitude not properly securing the wiring… Messing with it this am last time redid MB tape with 4011 much firmer and after looking at all the wire securing choices decided to go the popular European hot glue route. This seems the best and most secure. One more full power run for 10 min gonna put blades on hope to remaiden in am. Sorry for s pics had to use phone every rechargeable AA is dead thx to video gaming curtain climbers… Sent from my DROID3 using Tapatalk
#34 |
OK managed to repossess some AA's so got my Nikon back online.... better pics.....
I am unsure what method is best as I have only tried the hot glue but one thing is certain now after 24 hours curing they ain't coming out once hotglued lest you hack em out with the XActo.....
#35 |
Now I wanna hotglue everything especially this Spektrum sattelite cable coming off 7600.... The only glitch I am getting is sattelite consistently goes off line seems to be pigtail at rx. Anyone else with probs/fixes for this ? Thx
Anyone maybe try packing housing w/ dielectric compound maybe? Really small connectors, would hotglue as well but unsure this is the fix....
#36 | |
Atlanta RC Club, The only club inside the city. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. SAB USA Field Rep. Canomod USA Field Rep. Pulse Battery USA Field Rep. |
#37 | |
#38 | |
#39 |
Yes good points all but I do not have any wire strain problems. Coming out of AR7600 I am thinking you mean heatshrink behind satellite into pigtail? My thinking is problem is at connection w pins at rx.....
#40 |
OK I bought a tube of this goop stuff..... it says Amazing Goop on package and plumbing on tube, guess this is the right stuff.
Gonna try Alan and others ideas goop these Spektrum satellite wires try one more bench test.... I just wanna know it is not neglect on my part if it goes zooming off into the trees again.....
