Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters
Compass Model Helicopters Compass Model Helicopter Discussion
Old 03-10-2012, 07:50 PM   #41
sarpilot
I never tire of buying things for me…
Sent from my DROID3 using Tapatalk
"It's not the crash so much as the sudden stop"
Alees Rush 750, Compass 7HV, Compass 6HV, TRex450Pro, Blade MCPX, bunch of other junk in boxes
sarpilot is online now        Reply With Quote
Old 03-11-2012, 02:18 PM   #42
sarpilot
Is this the right goop stuff or is there another kind? not sure what kind of plastic on these spektrum sattelites but package says not for polystyrene, polyethylene, or polypropylene plastics.... thx
Old 03-11-2012, 04:23 PM   #43
dunkonu23
This is what I use.... whether or not it's right is... well... I dunno. It works for me.
Scott
Spartan Vortex VX1 Inside
Team A Main Hobbies/ProTek Field Rep
dunkonu23 is online now        Reply With Quote
Old 03-11-2012, 04:25 PM   #44
sarpilot
This is wrong then ty glad I did not open it this is for pvc pipe and stuff aparently....
Old 03-20-2012, 11:39 AM   #45
sarpilot
Well I am liking this goop stuff. It has fully cured 24 hours have done several bench tests cannot get satellite to go offline. Gonna run a few more packs through 450 then hopefully test hover 6HV later if it doesn't start pouring…
Old 03-20-2012, 01:05 PM   #46
Airworks
i use hot glue , did ircha at 110degrees with it no issues.and if it "lets go anywhere (as i also use it on wires through carbon frame routing.(so no wire chaffing).you jsut take a tip of the gun gun , no need to add more glue jsut heat it up and restick the object into it , on an rx , ive never had it let go.
Also , its instant cure.so hotglue , and go , no wait for it to dry.
Airworks is offline        Reply With Quote
Old 03-20-2012, 01:11 PM   #47
sarpilot
Ya I did the BeastX Spektrum and Gryphon w hot glue like it in those places… I was afraid to use it on the sattelite in case need to take wires out… may have to try it around the frame areas I've got enough glue sticks to last 50 years…
Old 03-24-2012, 06:18 AM   #48
OverTemp
Rule of thumb:
If it smells like solvent it's probably bad for electronics and circuit boards. Not just if it touches them, the vapors are bad too. Silicone is bad because it gives off acetic acid while curing... bad for electronics. The "food grade" silicone is supposed to be OK.
In the end, I'd MUCH rather "maintain" a glue gun than a tube of goop. The hot glue peels off perfectly too.
As far as the solvents... you may likely crash your electronics to death before the solvents do enough damage to matter, who knows... I'm just OCD with my $365 vBars.
1 - LOGO 600 stuffed with angry hornets
2 - A sad & lonely looking Rush 750 that I can't find time to finish.
3 - 7HV stuffed with over-tired honey badgers
OverTemp is offline        Reply With Quote
