| AleeS RC AleeS RC Inc. - Factory Support Forum |
The most interesting man in the world
Its Nuts......
It is so hard to really get the full effect when your not in person to see it Thanks Steve Eldred I love the Nose down Wall! and at the end the comment from Bill Kervaski
Charley Stephens To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Rotorworkz |
Man, Austin is a freaking prodigy. His flying is awesome.
BTW, Charley, your signature line?... You don't need anybody to hold your beer to watch Austin Fly... ![]()
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. AMA# 982814 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
No broken blades on that flight! Great flying, Austin!
Scott
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Spartan Vortex VX1 Inside Team A Main Hobbies/ProTek Field Rep. |
Nice work Austin!
It's not just a hobby... it's a lifestyle! Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo Pete Team Outrage. |
Theres my lil buddy spankin it!!!
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Kevin Williams AmainHobbies/ProTek Field Rep Rush700: Scorpion 4035-500kv, Vbar Silverline, CC160HV |
#6 |
Man. Too high of a head speed, That sounds like 26 to 2700 on the head,
What's the weight of the machine?
Team Minicopter , and USA X-era distributor |
#7 |
They are purposely testing it at an excessively high head speed to see how it will handle it.
#8 |
and it handles it well.. I've never seen this machine fail in any way with the high headspeeds being run on it. The only issues I have seen were when Charley forgets to take out a pitch leveling tool from the head or strap the flight battery down..
![]() I personally think 90 percent of us couldn't handle the Rush750 at those headspeeds. Its nuts. Even Charley doesn't want to fly it with this setup and he is a pretty dang good pilot.
#9 |
Austin is an animal...
#10 |
#11 |
Well that isn't the right way to test a machine , first off , this is telling people that they can run this machine at this high of a head speed, then they get other helis and do the same , Someone will end up hurt or killed because of extreme head speeds , That's a 445 mph tip speed with 2600 hs, Amount of shear force is close to 200 lbs on that blade bolt just spinning, that's not counting the forces from -14+ 14 degrees of pitch,
Videos like this makes me look away Is it good flying, yeh. Great job there, but it sure ain't smart
#12 |
![]() Btw awesome flying Austin
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. A Main Hobbies/ProTek R/C Field Rep RotorWorkZ ):> To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#13 |
#14 |
If some noobie thinks he's gonna beable to get his 700e to run like this without the crappy align head disinagrating he's got another thing comming its a test flight showing off all the hard work put into this bird. It looks like it paid off and ill probably run mine this same way changing head bolts after ever few flights.
#15 | |
AMA 125054 Rave ENV Total G |
#16 |
well first off, in secret, without showing videos to people, theres better ways to test the breakin points, no use flying with it to find out, just asking for trouble is all.
if you want pop out of a heli, its not to jack up head speed, its to make it lighter, a 10 lb 90 has about the some action like that, useing a 2000 headspeed
#17 |
Welcome to evolution in design, This Hobby changes every day if we did not we would still be flying Ni-cads, wood blades with no gyro, etc, etc….. Also this is not the only Helicopter on the market pushing extremes so no need to be in here singling me out. Your assumptions to this helicopters setup and forces applied are purely your speculation based on what you see in a video. If you don't like what you have seen it is noted in your post… now please move on!
#18 |
Well. I think you are the only manufacture showing extreme head speeds in 90 form on video, But I said my piece . I'm done, Good luck man!
#19 | |
http://www.youtube.com/euroncapcom It's a similar situation here. I'm sure AleeS will make it clear in the manual what's the highest head speed they recommend for this heli and they will also mention that "this RC helicopter is NOT a TOY". |
#20 | ||
