Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X5
X5 Discussion and support of the Gaui X5
Old 02-06-2012, 08:21 PM   #1
mamartin
Default Swashplate slop?
After flying several batteries today when I went to fold up the main blades and put the X5 up I noticed there was a little play in the blades. Once I got home I went thru it all and found when the blades are folded back I can feel up and down play that is coming from my swash.
Is this common or should I replace my swash? I haven't had any misshap's with this swash and it has less than 40 flights on it since its replacement and it is the new style swash plate
iKON field Rep
GAUI NX4 with iKON, EDGE blades O.S.37
GAUI X5fes, iKON, Edge blades, CC 20amp BEC pro,
Align 600Npro, iKON, OS55HZ, Funkey B320 3D pipe, Radix Blades,
mamartin is offline        Reply With Quote
Old 02-07-2012, 01:07 AM   #2
Harrow
There's been some discussion on this recently in this forum. Here's the thread...
http://www.helifreak.com/showthread.php?t=287624
Harrow is offline        Reply With Quote
Old 02-07-2012, 01:31 AM   #3
mamartin
Thanks for the link that's exactly what I've got going on.
iKON field Rep
Old 02-16-2012, 08:36 PM   #4
mamartin
FYI. I'm not sure if my swash started getting sloppier here in the past couple days but it sure felt like it
So I went ahead and picked up a new one from my LHS but the thing about is that luckily he stocks up on lots of parts because the first 3 swash plates had the beginnings of that same slop feel in them. It took feeling thru a few of them before I found one that felt good and solid without play.
I'm going to take my older swash apart and see if there is anything that can be done to tighten it up or not. I will post back if I find a way to tighten it.
After looking more closely at it i may be wrong but I don't think that the washer trick is going to work on this new style swash
iKON field Rep
Old 02-17-2012, 04:15 PM   #5
mamartin
ok I found out today why I was feeling the slop and others out there may also have this issue so hopefully this helps anyone else out who is having this.
There is a retaining ring underneath that has 4 threaded holes in it that are used for just allowing a way to grip it to enable you to be capable of either tightening it or loosening it. Gaui sells a tool that you can use for this very purpose but I just used a larger sized alen wrench and laid it across 2 of the bolts and used it as leverage and found out that my retaining ring was working itself loose. So I went ahead and removed it and replaced the bearing in it just because it made me feel better about it and then applied a small amount of loc-tite on the threads of the ring and tightened it back down tight, removed my "grip" bolts and checked it and the slop was no longer there.
I feel confident now that it will not develop anymore slop.
Here are some pictures of what I did, I hope this helps others to figuring out there swash slop issues
Mike
Name:	X5 swash pics 002.jpg
ID:	290605   Click image for larger version
Name:	X5 swash pics 004.jpg
ID:	290606   Click image for larger version
Name:	X5 swash pics 005.jpg
ID:	290607   Click image for larger version
Name:	X5 swash pics 011.jpg
ID:	290608   Click image for larger version
Name:	X5 swash pics 008.jpg
Name:	X5 swash pics 009.jpg
ID:	290610   Click image for larger version
Name:	X5 swash pics 010.jpg
ID:	290611   Click image for larger version
Name:	X5 swash pics 012.jpg
iKON field Rep
Old 02-17-2012, 04:23 PM   #6
fatalsync
Good tip. Will have to remember this one.
DX8, mcpX, Align T-Rex 450 SE v2 FBL(BeastX, Tarot Pro V2 Head), Gaui X5 FES Sk540
Thanks and Gig 'Em
fatalsync is offline        Reply With Quote
Old 02-17-2012, 04:23 PM   #7
helidude71
Very helpful.
I hope I don't need it, but when it gets sloppy I know how to fix.
T-Rex 500 ESP FBL, Microbeast v3, Scorpion HK-3026-1600, CC ICE 75
TSH Gaui X5 FES, Microbeast v3, S.Bus, DS610s, DS650, YGE 100LV
Futaba T7C
Phoenix R/C v4
helidude71 is offline        Reply With Quote
Old 02-17-2012, 05:16 PM   #8
browndog
Awesome Tip for sure. I wonder where you could pick up the tool. You would think Gaui would give us this tidbit of info
browndog is offline        Reply With Quote
Old 02-17-2012, 05:36 PM   #9
mamartin
Dave at anythingheli.com has them but it's not needed in order to service the swash just put some bolts in those holes and use a larger Allen wrench or screwdriver across the 2 bolts in order to tighten or loosen that ring
iKON field Rep
Old 02-17-2012, 05:46 PM   #10
browndog
very cool
Do those bolts need to be a certain size?
Old 02-17-2012, 06:10 PM   #11
mamartin
Yeh if I remember right they are 2mm bolts and you need them as short as possible and don't screw them all the way into the bearing or you may ruin the bearing
iKON field Rep
Old 02-17-2012, 07:22 PM   #12
browndog
Thank you sir !
