Go Back   HeliFreak > R/C Helicopter Support > E-Sky Helicopters > King II/III/IV and CP 2/3
King II/III/IV and CP 2/3 E-Sky King 2, 3, 4 plus CP 2 & 3
Old 02-08-2012, 11:05 AM   #1
helinamer2345
Default Foam blades won't track solution fix heli rc
When you have the carbon replica foam blades they need sanding and taping. They have a sharp edge on the leading edge. Sand it with fine paper and check it. Do the tips also. Then apply any slick tape to the top and bottom so that the leading edge overlaps and gets 2 layers.
I made it so the tape was only on the front half of the blade adding weight forward.
The handling was terrible on the 315mm regardless. The 275mm are naturally stuffer and fly/track better.
helinamer2345 is offline        Reply With Quote
