| Align 3GX FBL System Align 3GX FBL Flybarless System Software and Hardware Support |
Hello, I´m new in the forum so first of all I would like to say hi and sorry in advance for my english as I´m not a native english speaker.
I´ve got a trex 450 pro v2 3gx super combo ( what a long name), I have it all mounted and when I enter DIR mode on the 3 gx on step 1 (DIR) i check that the swashplate and the rotor head are level (they are) and that all the controls move in the right direction (they do). Then I go to step 2 (E.LIM light) and move my radio stick al the way forward to set the limit and then back to neutral, then on step 3 (E.REV) I tilt the helicopter nose up/down but the swashplate doesn´t move at all, well just 1 mm and a bit randomly and slowly. The same happens on step 5 (A.rev) it doesn´t move when tilting the heli right/left. when in the first step everythng is moving ok, but looks like the internal gyros of the 3gx are not responding when I tilt the helicopter. Please help!!! ![]() Thank you very much in advance for your help and sorry for the long post. |
Try turning the gain up a bit so there is more interaction with movement , put the gain pots to about 1:30. When checking watch for the initial movement when you til the heli.
Thanx bad007, i put them all the way to maximum and does more or less the same, I don't know how much it should move when i tilt the heli, but it moves very little and is not very agile when i move it from one side to the other. Thank you again for the help.
#4 | |
Don't leave the gains up the whole way when you go to fly, return them to 12:00 for first flight and then tweek them up a little at a time. |
Just an FYI - The first time I set up my 3GX, the swash moved during this step as outlined in the manual. The second time I went into setup mode, it did not tilt - it did the exact same thing you are describing. It flys fine, however... you can check the tilt by turning on throttle hold when it's in regular mode - it's just both aileron and elevator channels will be live at once.
