| 550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
Finished my 550 FBL V2 a few weeks ago. The strap or holder that goes around the boom that you glue the metal tube control rod glide into seems to push my control rod down. If I take it off it sits much straighter. Anyone have this issue on theirs AND will it cause a problem for me? Tail seems to work ok im just thinking in terms of binding or actually popping the ball links off in flight. Wondering if wrong one was put into kit. Thanks
Have u fixed the guide on a slight angle or pointing straight down?
The metal tube glues to the control rod not the guide. |
I did wonder too about this, the pushrod when detached from the servo end does spring a little away from the ball link, my guide on the boom is at a slight angle for a median line to the tail. The metal sleeve is glued to the pushrod central to the boom guide, the angle servo to tail control arm is slightly out but not worried myself.
TREX 550E LOGO 500SE & 600SE & 600SX Synergy E7 zzzzzzzzzzzzzzTDR |
You are not alone. A buddy of mine pointed this out a while back. He uses Quick UK Tail Push Rod Kit. Here's the link to the black one.
http://www.readyheli.com/TX55T24-BK-...k_p_37843.html ReadyHeli used to sell just the clamp with push rod quide but I can't find the link. Even though the stock one did not give me any issue, I swapped it with Quick UK kit. Another buddy flies it without the guide for years without any issue.
Cheater To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
I know my 450 i use a solid cf rod with no guides and no problem.
Now im building my 550 just got the ar7200bx and going to be setting it up soon i will think twice about the guide.. But this rod is much longer, mabey others can chime in Guide or no Guide ![]()
Dx7,T-550Ev2,T-450 pro Dfc, 130 X, mcpX BL Brushless Nano RUSH 750 being built To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#6 |
I glued my metal piece to the rod guide. I didn't think it would go through the guide once it was tightened up to the boom. Irregardless its still pushing down a bit. thought of modiflying if with my dremal to release some of the downward pressure. Trying to keep tail slider as slippey as possible and this is the last link in the chain.
#7 | |
To correct it I elongated the guides pushrod hole until the rod could make the trip to the tail without bowing when connected. I filled the area of the elongation with a balsa shim, then ca'd it and the metal guide tube to the guide. The only thing I might do differently would be to glue the guide tube to the pushrod instead of to the guide itself. |
#8 |
gehrbox
That is exactly what im gonna do with mine. That was my concern too that over time the pressure would pop the link off in flight. Wasn't sure if this part was off a 600 or 700 and was the wrong one for the 550. |
#9 |
Are we talking about the carbon fibre tail control rod? (I'm assuming we are) If so, the metal sleeve gets glued onto the control rod itself, and not the guide that attaches to the tail boom. The sleeve is meant to protect the carbon fibre from fraying and wearing from moving through the guide, and possibly breaking in flight.
AMA #959523 "Helicopters don't fly... they just beat the air into submission." |
#10 |
I had the same thought. I figured it was from a 700. Anyway I just altered mine so that the metal sleeve is now glued to the pushrod instead of the guide per the recommendation of Kenny.
#11 |
The worst but for me was the glide being off line on the boom,
I glued the metal tube to the CF rod but didn't like the way the glide would move on the boom and if you tightened up the glide it would bind so I made a metal tube longer than the align one by 50 mm to go on the glide and be tightened up, that way the CF rod with the align metal tube runs in side my tube, a dab of grease and it works a treat, it's now smoother and stays in line on the boom, |
#12 |
I've been running a CF tail pushrod with no guides for almost 300 flights and no issues.
Zen and the Art of Helicopter Maintenance Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.) CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG. T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades. |
#13 |
+1 CF control rod & no guides.
"Sort your head out and fly with your heart" Trex 450 SE V2: 9257 tail, Spartan Quark, HS65mg cyclic, DX7-AR7000, NEU 1107h/2y, Jazz Esc, Trex 550 FBL: Jive 100+LV, KDE/NEU 1907H/1/N42, Vbar 5.3, Futaba BLS 251 |
#14 |
+2 cf no guides , i tried it after after getting an idea that is could help unrestricted movement of the rod less load on the servo , it works
Sanwa SD10G ,T-Rex 550.V2 FB Kde 600XF ,T-Rex 450 Pro.V2 3GX + KDE ,M120D01 ,V120D02S To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#15 |
#16 |
The links are pretty tight on the servo and tail linkage. I think it should be ok. Any one else running their 550 without the guide?
Quilting is my other passion. |
#17 |
Ended up taking mine apart and cleaning everything up. Glued the metal tube to the CF control rod and then reamed out the guide till the rod had no down pressure on it. Seems to be pretty smooth now. Still don't know why they just didn't make it fit right in the first place. I kinda feel better having the guide in place. Guess it really doesn't matter cause if it popped off at the servo or the tail in flight you would be doomed either way.
#18 |
Just finished my new and first AR7200BX setup and i decided to leave off the guide.
Its on tight ! + no problem on my 450 + as previous poster said if it comes off well its doomed with guide or no guide lol My goal is to maiden it next weekend woooohooo !
#19 | |
#20 |
Well said Mmarian. I have just finished my 550 build and now am looking at a "next" build and I do like the Logo's by mikado but their prices seem to be right up there. This 550 was my first build (after rebuilding my B400 countless times) and I felt the quality was right on par with what I paid for the kit. i would not hesitate to get another align kit. Kinda like the MSH protos too but don't know much about them.
