Go Back   HeliFreak > R/C Airplanes Info and Support > Airplane Related
Airplane Related R/C Airplanes Discussion
Old 03-19-2012, 01:40 AM   #21
rotorfan
Covering here and decided on a scheme, So I got started. Not to good at covering and have a hard time keeping it simple. Heres what I have so far. Colors are Ultracote flame red and silver. Hmm not letting uploud photos will try again tommorow.
rotorfan is offline        Reply With Quote
Old 03-19-2012, 05:47 PM   #22
rotorfan
Photos
Name:	venture .60 153.jpg
ID:	300280   Click image for larger version
Name:	venture .60 155.jpg
ID:	300281   Click image for larger version
Name:	venture .60 159.jpg
ID:	300282   Click image for larger version
Name:	venture .60 160.jpg
ID:	300283   Click image for larger version
Name:	venture .60 151.jpg
Name:	venture .60 132.jpg
ID:	300285   Click image for larger version
Name:	venture .60 146.jpg
ID:	300286   Click image for larger version
Name:	venture .60 138.jpg
Old 03-24-2012, 11:10 PM   #23
rotorfan
well wasnt happy with the way the silver sides came out so I ripped them off and started over. So re did them and got the turtle deck done, Will have more time this week so I should be able to progress a bit faster.
Name:	venture .60 228.jpg
ID:	301776   Click image for larger version
Name:	venture .60 230.jpg
ID:	301777   Click image for larger version
Name:	venture .60 232.jpg
ID:	301778   Click image for larger version
Name:	venture .60 233.jpg
ID:	301779   Click image for larger version
Name:	venture .60 236.jpg
Name:	venture .60 237.jpg
ID:	301782   Click image for larger version
Name:	venture .60 238.jpg
ID:	301783   Click image for larger version
Name:	venture .60 240.jpg
Old 03-25-2012, 08:25 PM   #24
rotorfan
Default Slow but sure
Front deck. Might run a red stripe down the side to break up the silver.
Name:	venture .60 250.jpg
ID:	302117   Click image for larger version
Name:	venture .60 253.jpg
ID:	302118   Click image for larger version
Name:	venture .60 254.jpg
ID:	302120   Click image for larger version
Name:	venture .60 255.jpg
ID:	302121   Click image for larger version
Name:	venture .60 258.jpg
Old 03-27-2012, 07:06 PM   #25
rotorfan
Wow took me about 4 hrs. to draw, the template for the stripe cut it then trace and cut the ultrcote then apply the stripe, still need to remove a few bubbles, not totally satisfied but it will work.
Name:	venture .60 261.jpg
ID:	302614   Click image for larger version
Name:	venture .60 262.jpg
ID:	302615   Click image for larger version
Name:	venture .60 266.jpg
ID:	302616   Click image for larger version
Name:	venture .60 267.jpg
Old 03-28-2012, 09:43 PM   #26
rotorfan
Left side done along with stripe over turtle deck. Now just the bottom rear of fuse then onto the wing.
Name:	venture .60 278.jpg
ID:	302925   Click image for larger version
Name:	venture .60 280.jpg
ID:	302926   Click image for larger version
Name:	venture .60 282.jpg
Old 03-29-2012, 12:21 PM   #27
memosteve
It's coming along very nicely...good looking plane, almost too pretty to fly!
HeliDirect.com Team Pilot/Rep
Align T-Rex 700LE FBL, OS 91HZ-R, Hatori SB-20, Beast X
Align T-Rex 600LE FBL, OS 55HZ, Beast X
Outrage Velocity 50N2 FBL, OS 55HZ, Beast X
memosteve is offline        Reply With Quote
Old 03-29-2012, 12:28 PM   #28
rotorfan
Thanks memo. But she will fly Maiden I figure will be about 2 weeks providing we get some decent weather here. Will be running full telemetry and smoke!
Old 04-01-2012, 07:10 PM   #29
rotorfan
Started covering the wing. Stripes are on the bottom obviously,there will be some kind of red on the top just not sure yet. Dont think I will ever use silver again seems harder to work with than any other color I have used and very unforgiving.
Name:	venture .60 288.jpg
ID:	304138   Click image for larger version
Name:	venture .60 289.jpg
Old 04-11-2012, 10:19 PM   #30
rotorfan
Havent had much time lately, but got a bit more done today (top wing stripe).
ID:	307029   Click image for larger version
Old 04-23-2012, 10:12 PM   #31
rotorfan
Well back at it after a bit of a break due to family issues. Just gotta cover ailerons then I can start final assembly.
Name:	venture .60 295.jpg
ID:	310697   Click image for larger version
Name:	venture .60 296.jpg
ID:	310705   Click image for larger version
Name:	venture .60 299.jpg
ID:	310711   Click image for larger version
Name:	venture .60 301.jpg
ID:	310713   Click image for larger version
Name:	venture .60 305.jpg
Old 04-26-2012, 11:25 AM   #32
rotorfan
Ailerons covered and final assembly started.
Name:	venture .60 309.jpg
ID:	311391   Click image for larger version
Name:	venture .60 297.jpg
ID:	311392   Click image for larger version
Name:	venture .60 298.jpg
ID:	311393   Click image for larger version
Name:	venture .60 318.jpg
Old 04-28-2012, 07:24 PM   #33
rotorfan
Well ready to figure out were to put elecs. and smoke oil tank so it all balances,then I can install them along with all control rods, fuel lines etc. left bottom rear of fuse uncovered for now just in case I need to but battery back there to balance. Gettin close I dont think it looks to bad.
Name:	venture .60 321.jpg
ID:	312119   Click image for larger version
Name:	venture .60 322.jpg
ID:	312120   Click image for larger version
Name:	venture .60 323.jpg
ID:	312121   Click image for larger version
Name:	venture .60 328.jpg
ID:	312122   Click image for larger version
Name:	venture .60 331.jpg
Name:	venture .60 342.jpg
Old 04-30-2012, 11:23 AM   #34
memosteve
Outstanding job! Plane looks fantastic!
Old 04-30-2012, 12:21 PM   #35
rotorfan
Thanks memo.
Old 07-07-2012, 01:28 PM   #36
rotorfan
been awhile but heres a vid of initial smoke test with macs pump less smoke system gonna adjust valve to open a bit more to allow more oil flow, ran out of fuel at end of vid.Bear with my videographer.
Old 07-07-2012, 01:41 PM   #37
rotorfan
video not showing seems I forgot how to post a video from you tube...
Old 07-08-2012, 12:04 AM   #38
rotorfan
fixed it
