Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X5
X5 Discussion and support of the Gaui X5
Old 02-12-2012, 04:09 PM   #1
helidude71
Default FES X5 CNC main rotor yoke doesn't fit
Is it normal that the main rotor yoke doesn't fit smooth onto the main shaft?
From my Align kits this just drops on it and bolt down.
I have to use some serious force to press mine onto the X5 shaft.
To be honest I think I f**cked up and wasted it.
When I run the motor the head stopper wobbles seriously.
TSH Gaui X5 FES, Spirit, S.Bus, HW100A V3
TSH Gaui X3, Spirit, 6S, S.Bus, HW50A V3
Futaba T7C (I admit, also a Spektrum DX8 and some planks.) ;-)
Phoenix R/C v5
helidude71 is offline        Reply With Quote
Old 02-12-2012, 04:27 PM   #2
Chris Sexton
No. If anything mine was loose and I had to really tighten the bolt to get the head tight.
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote
Old 02-12-2012, 04:44 PM   #3
helidude71
Thanks!
At least I know tolerances are not on my side with this kit.
Phoenix R/C v5
Old 02-12-2012, 06:01 PM   #4
s76 mech
Mine was actually abit sloppy on the MS. I put it in a vise and crunched it down until it was nice and snug on the MS. No more slop. Its solid now, even after a crapload of flights.
s76 mech is offline        Reply With Quote
Old 02-12-2012, 06:21 PM   #5
crf69
mine is very tight.....tighter than i would like but its ok i am sure
crf69 is online now        Reply With Quote
Old 02-12-2012, 06:59 PM   #6
dannylightning
Mine had a Burr in there, I got a new one and it fit good a friend had a 8mm drill bit and got the burr out of my origional head block,
the new one I got fit perfect
Sent from Samsung galaxy player, spelling and grammar might be worse than usual.....
Blade 180 CFX, Sold the rest of my stuff, I dont really fly all that often any more.
dannylightning is offline        Reply With Quote
Old 02-13-2012, 02:39 AM   #7
Harrow
I had to push fairly hard down on mine to get it on. I guess I should have checked inside it for burrs, etc. It is nice and straight.
Harrow is offline        Reply With Quote
Old 02-13-2012, 06:06 AM   #8
torana74
One of mine has been quite tight but flies perfect.
Vas
GAUI X7, GAUI X5 all vbar.TT 12S Hurricane 550 beastx
GAUI
Field Rep, Team Empire Hobby
torana74 is offline        Reply With Quote
Old 02-13-2012, 11:54 AM   #9
helidude71
Seems like Gaui still has a QC problem if you ask me.
Problems i have seen so far:
- Frame stiffener screws (the longer ones) don't fit. Holes inside the CNC servo mounts are not deep enough.
I can fix it by using the shorter stock screws.
- Tail slider sticky. I can fix it with a small washer.
- Yoke doesn't fit on main shaft. Needs replacement.
- Main gear has some up-down play, makes it wobble. Not sure how to fix this. (Needs shim I don't have I guess.)
(If I lift the main gear up you can see a small space above the C-clip.)
To be honest I'm sick of it, paid a lot of money and it's not a "pleasure to build" like everybody says.
Sorry for the rant.
Phoenix R/C v5
Old 02-13-2012, 12:49 PM   #10
dannylightning
Sorry for the rant.
yeah, i had a few issues, the head block having the burr inside was the only thing that was really a issue. but once you get it flying well the machine preforms.
Old 02-13-2012, 01:51 PM   #11
helidude71
I do hope so Danny.
Phoenix R/C v5
Old 02-14-2012, 12:56 AM   #12
Harrow
Sorry for the rant.
My only problem was missing 2 screws for mounting the servos. Not a big problem, but very frustrating when it stopped me from being able to maiden one week.
My only other scratch build was a HK450, so it has been a pleasure for me in comparison.
Old 02-14-2012, 10:25 AM   #13
dannylightning
every kit i buy is missing screws, except for the gaui... that was nice for a change.
Old 02-14-2012, 03:19 PM   #14
helidude71
My Align kits never missed a thing. Maybe I'm just lucky on that.
Now you say about screws, on the swash servo arms you need three M2 screws to fix the balls.
Two where the correct lenght but one is short.
I wonder why they don't put three M2 screws of the same lenght inside the kit?
It's always possible to make it a little shorter if needed, but not longer.
Phoenix R/C v5
Old 02-14-2012, 03:21 PM   #15
helidude71
You're right, I guess it's a pleasure when you come from a HK build.
It's all relative.
Phoenix R/C v5
Old 02-15-2012, 05:16 AM   #16
Harrow
Oh yeah, I also had that problem. Downright annoying!!
Old 02-15-2012, 05:41 PM   #17
rotaryguy
The X5 FES I built the head was darn near press fit.
rotaryguy is offline        Reply With Quote
Old 02-16-2012, 12:04 PM   #18
helidude71
In other words, you needed a lot of force to get it in place?
How did you manage?
Phoenix R/C v5
Old 02-16-2012, 12:48 PM   #19
rotaryguy
Very carefully
I polished down the upper portion of the mast with 600+, lined up the head and tapped it down with a plastic/hard rubber mallet after removing a bit of material from the main shaft.
Old 02-16-2012, 01:29 PM   #20
Harrow
I'm wondering if the problem is due to paint inside the head? Perhaps they are machined correctly, but the paint makes it tight? Or are they anodised, and does that still add thickness?
