Old 02-13-2012, 08:31 PM   #1
bj660raptor
Default tail question
i have a logo 600 and i was wondering if someone could tell me the length of the tail control rod center ball link to center ball link,or post a top view pic of the tail and what 3deg against torque looks like with servo arm at 90,,,,,oh btw this logo is the best heli ive ever flown,tia guys
Trex 700DFCHV,helijive,vbar 5.2 pro
Goblin 500 bls 153,bls 251,jive 100,pyro 600-12 20t pulley,mini v 5.3 pro
Rockin TP 65c and 70c and Futaba 8FGS.
Pilot Brandon J.
bj660raptor is online now        Reply With Quote
Old 02-13-2012, 11:51 PM   #2
bj660raptor
anyone?
Pilot Brandon J.
Old 02-14-2012, 08:35 AM   #3
Big Fil
At work, so not in front of any machines at the moment. I will try to take a look tonite if no one can jump in with the exact measurement.
That said, you might find one brand tail servo needs a slightly different length than the next due to where the output shaft is located. I'm running JR8900 and BLS451s in mine and with the ball links inserted all the way into the control rod guide it's usually right on the money. With the servo arm at 90 and looking straight down on the tail then the bell crank should be 90 as well. You can use bracket that the bell crank is mounted as a reference to sight the 90 degree when looking top down.
Mikado Model Helicopters
Edge Blades
Big Fil is offline        Reply With Quote
