I guess every model will have a version!
![]() Flight test Flight test 2 |
Looks great. Makes me want to sell my unused TracX head for my 500ESP and get that one. Might sell it with the BeastX too, I can't get it set up it seems very complicated to me, too many menus and options. Manual tells you _how_ to change settings but not _why_ you would want to. That is my issue, deciding what to set things as. But anyhow, I digress. This is not the time/place for a rant...
But that DFC head sure looks pretty. I might have to stick with FBL after all
DX8 / Trex 500ESP BeastX.TracX.EDGE / Trex 600 Nitro LE / Trex 450Pro V2 3GX / Blade SR.mSR.mSRX.mCPX / UM Pole Cat.UMX Beast.UM Stryker 180.UM P-51 / Concept X EDF / Skytrainer 182 / Phoenix 3.0 AMA #970045 |
the beastX is one of the simplest FBL controllers out there.
Do the setup per instructions, the trim pots are not that hard to work out, the only other thing to worry about is the flying style pre-sets, just pick one. If you don't like it pick another... Back to the topic at hand, i wonder how the mechanical gain is on their head, the old Align head you could get spot on with Vbare, the EFL head was not as good and needed some modification to get right, so where will this head sit? mechanically that is...
Dave Goblin 500, Vbar, BLS153, BLS251, Kontronic Jive & Piro MutliWiiCopter Scarab Stealth Armour, Scarab TriiKopta, Scarab Octa, Scarab Vampire |
When will this head be available in the states cause I totally destroyed my fb head today
Trex-450 sport .....Trex 500 Raptor Titan 50 ys 56.ds610+650 gy520 T-rex 600 pro fbl scorpion 4035-560 CC hv 80 beastx ds610+650 all on 10s |
Damn, i literary just bought all the parts from the pro version to convert my esp to fbl 2 hours ago !!!. i could have just waited for this one.
#6 |
...you gotto love it... "..Avg headspeed 3150rpm"
#7 |
3150 is what I swing on my 450Pro
No Plankers were injured in the making of this post! TOY BOX contents Mcp x, 450 Pro VBar, 500 VBar, 12S 600CF VBar... Mikado Logo 6003D VBar Proudly flying KBDD, MKS, Castle, Scorpion and some planks too To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#8 |
Why so high headspeed?
Michalis. Trex 700N LE V-Stabi - Trex 500 ESP V-Stabi - Henseleit TDR! ...and let the flying be second nature! |
#9 |
3150 AVG = 3 minutes flight time
I will give them this, it was one helI of a 3 minutes
#10 |
All parts are exposed to high strain, that means early wear. Don't think a 500 has ever been designed for such speeds unless you have a sponsor
#11 |
I can't believe the batteries would last very many cycles at that HS.
The head looks cool though! I want one!
#12 | |
HeliTach said 3800 rpm....gotta back down on my pinion I think
HK Best Of Custom 450s & 500 Build Different! |
#13 |
I muchhh prefer alan szabo why isnt he flying there anymore??
#14 | |
![]() ![]() Be careful, may create a cataclism upon a crash!He surely got bored of doing whatever he wants with a heli so now have put some rx to a stone and experiencing some new maneouvers. |
#15 |
Looks like the 500 DFC head price will be reasonable at 59.99. http://*********.com/align-500-dfc-head-price-revealed/
Is this head going to work with the ESP?
Compass 6HV - SK540 - MKS HBL665/669 Trex 500 ESP - SK540 - 510's/BLS251 DX8 / Phoenix / Persistence ~"See the heli, fly the heli"~ |
#16 | |
#17 |
I took a closer look at the add photo, for 59.99 your getting a shaft, the head block, and new arms... You are not getting the blade grips, or the swash!
So add 25.00 for grips if you don't already have them.
#18 | |
#19 |
I didn't catch that, it was late. In that case it won't work with the ESP grips.
Yes that looks like the ones duytang.
#20 |
Align are selling all the DFC heads as "upgrade kits" so you don't get grips, spindle thrust bearings
In their wisdom they figured we would all just be pulling our existing "pro" heads apart and upgrading. I was seriously thinking of getting one of these except one small issue has come up that is making me hesitate: The main shaft (new lowered one specifically for this head) is NOT available as a spare part on the 700/600/550. Thos heads have been on the market for over a month now and there is NO spare part support for them.... Come on Align....
