Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCP X Brushless Mods
mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions
Old 02-14-2012, 09:13 PM   #1
golfgolf4
Default hpo8s rewind
A friend i met here on the frreak was nice enough to rewind a hpo8s for me and i know ive said this everytime i find another motor that blows my mind but cant help it...wow my oh my this thing is sick ,,,ive done a garage video of my spin 15500 and my hpo6v2 and am going to do spin 16300 and this crazy bad to the bone rewound hp08s real real soon ...Thank you Mr D
golfgolf4 is offline        Reply With Quote
Old 02-14-2012, 09:17 PM   #2
fr34k
Nice, can't wait to see the video, who rewound it for you?
fr34k is offline        Reply With Quote
Old 02-14-2012, 09:27 PM   #3
Ampdraw
I'm guessing the guru of HP08 winds...Don.
http://www.rcgroups.com/forums/showthread.php?t=1400817
Look forward to the vid!
Amp
Ampdraw is offline        Reply With Quote
Old 02-14-2012, 09:35 PM   #4
fr34k
How does the power compare to the 915 etc?
And how does the size (diameter especially) of the HP08 compare?
Old 02-14-2012, 09:39 PM   #5
golfgolf4
dont know about the Ta 915 ive been trying to get one for months everytime i goto order one ther out,,,and always have a newer different version
Old 02-14-2012, 09:42 PM   #6
fr34k
Does it fit the plastic frame without too much cutting?
Old 02-14-2012, 09:49 PM   #7
superjet112x
Definately want to see that video
Trex 700n DFC Beast x...Trex 600n Beast x...
Trex 450 pro V2 DFC Beastx KDE XFC Ice lite 50
MCPXs'' HPO7..HPO5s..CO5m..V2 stock..Nano Cpx
Blade 300x Phoenix 25esc Park BEC Blade upgrades
Ducati Desmo 1/5 scale nitro superbike
superjet112x is offline        Reply With Quote
Old 02-14-2012, 09:59 PM   #8
dbennettya
Nope it takes about the same mods as the HP05S. I tested the stock frame with just the rewound HP08 and OMG the frame flexed and shook like crazy just from the motor speeding up and slowing down That thing should have crazy power in an mCP X
Yes Amp, I did the rewind and it can even be way more powerful but the trade off is current vs battery capability vs weight vs flight time. The data will determine what is best. BTW Papat did the engineering on this and it worked out to be a worthwhile collaboration as many folks are enjoying the benefits.
This rewind is four turns of three strands of 32 AWG in a Delta configuration which gives 18,680 KV. This is the same rewind that I use in my Hybrid 4G6 FBL helis which gives ~250 grams of thrust
Don
dbennettya is offline        Reply With Quote
Old 02-14-2012, 10:03 PM   #9
fr34k
What motor (with rewind if necessary) would be the most powerful light motor?
I still can't find any advanced 3D pilots to tell me how much power is really needed for 3D and how much of this is just more power for the sake of more power
I just want a motor that gives the mcpx enough power to do all the maneuvers my big helis can do while remaining as light as possible
Old 02-14-2012, 10:06 PM   #10
golfgolf4
Thank you Don and Papat
Old 02-14-2012, 10:13 PM   #11
Ampdraw
You ask alot of very specific questions but I don't see much given back here
Perhaps you help on a bunch of other forums?
Buy one of the motors and start testing!!
By the way the dimensions of both the HP08 and the 915 can easily be found on the net.
Read plenty of your posts so this one isn't being focussed on.
Amp
Old 02-14-2012, 10:17 PM   #12
fr34k
I spent half an hour creating a motor bible and volunteered to update it daily with any info people would like to share as an attempt to give something back but nobody bothered
Old 02-14-2012, 10:18 PM   #13
ShaneJourdan
The limitation of the MCPX is not the main motor but the tail. We now have the best solution at present for tail control and it will allow most maneuvers. Any good BL motor that can product about 6900 rpm will be the ticket add to it a CC 10amp programmable ESC in GOV mode and your loven life. I believe the best choice with consideration for weight is the HP06v2 16200KV motor. Its a screamer.
keep in mind the tail only works well in one direction, the other direction relies on stored energy.
Goblin 700 - XF495 KDE - HC3SX - CC160
Trex 700 - 700 MX - HC3SX - CC120
Blade 450X - Scorpion 2221-6 - BD3sx -CC 50
Gaui X2 - BD3sx - Talon 25 - DS95i
ShaneJourdan is offline        Reply With Quote
Old 02-14-2012, 10:19 PM   #14
golfgolf4
spin 16300 for sure
Old 02-14-2012, 10:19 PM   #15
dbennettya
Maybe a post with a poll? I can't do all the possible maneuvers so can't say.
My mCP X with HP05S can fly horizontally with the nose up for ~30' or more when I bail from a botched maneuver. I'm only running HP08S and 8T pinion with an OS 400mah 20C battery with XP-7A and the Steve. I haven't opted for my rewind yet in the mCP X....I'll let Pete report on that.
Don
Old 02-14-2012, 10:22 PM   #16
ShaneJourdan
Originally Posted by golfgolf4 View Post
spin 16300 for sure
Have you tryed the HP06 v2? IMO its a much better motor...
Old 02-14-2012, 10:25 PM   #17
golfgolf4
yes i love my hpo6 he asked for all around best performance id have to say its probly a tie then hpo6 is more powerful but spin int lacking in the power dept either...ther both great motors
Old 02-14-2012, 10:33 PM   #18
golfgolf4
heres my list and ive personally tried them all
hpo8s-dp (Don.Papat}Rewind
hpo6v2
spin 15500
spin 16300
spin14000
hpo5s
co5m
helimax cp mottor(brushed)
stock
and as mr>Don would say ymmvmy 2 cents
Old 02-14-2012, 10:46 PM   #19
ShaneJourdan
Agreed!
