Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > Mini CP
Mini CP Walkera Mini CP Helicopter Support
Old 02-16-2012, 12:33 AM   #1
Heli-opolis
Default Leaning tower of Mini-CP
This may be more of a general heli setup up question but in the few flights I have had with my new Mini, I notice that it leans to one side. It doesn't necessarily want to always roll to that side but then again with 3-axis gyros, I'm not sure it would.
I thought it might be a balance issue but when I checked the balance left to right by lifting it off a surface from its CoG I found that strangely enough, or maybe not so strange, it balanced in the opposite direction.
Is it simply a balance issue and if I balance it out statically, even if in the opposite direction of what flight characteristics would suggest, it will balance out in flight?
With the nitro heli's, balance was rarely an issue because something had to be pretty out of whack before it had much affect but when the bird weighs but tens of grams, it would seem balance is much more important.
Did I just answer my own question or off on a stroll in left field?
Heli-opolis is offline        Reply With Quote
Old 02-16-2012, 07:51 AM   #2
ebeing
Sounds like the tail rotor torque.
http://en.wikipedia.org/wiki/P-factor
Sounds normal.
130x | mCPX | mSRX | DX7S | mCPX BL
ebeing is offline        Reply With Quote
Old 02-16-2012, 09:32 AM   #3
Magnum80
All helicopters lean, except dual rotors. Clockwise rotation leans to the right. CCW rotation leans to the left. Has to lean to counter blade torque.
Magnum80 is offline        Reply With Quote
Old 02-16-2012, 12:18 PM   #4
Heli-opolis
Thank you both very much.
I guess it just wasn't as noticeable with my larger helis in the past although my faulty memory could be due to 'Old-timers disease'.
Old 02-19-2012, 11:56 AM   #5
jonbailie
You'll notice it a little more on a flybarless helicopter too.
// T-Rex 600EFL Pro 3GX // T-Rex 450 Pro V2 3GX // T-Rex 250 Pro DFC 3GX //
// Walkera V120D02-S (x2) // Walkera V120D02 // Walkera Genius CP (x3) //
// EFlite Blade MCPX (x2) // EFlite Blade 120SR // E-Sky Belt CPX //
// WK2801 // Spektrum DX4e //
jonbailie is offline        Reply With Quote
