Go Back   HeliFreak > R/C Helicopter Support > Synergy Model Helicopters
Synergy Model Helicopters Synergy Model Helicopters Support
Old 02-16-2012, 05:30 AM   #1
beans07
Default Anyone using MKS or Outrage servos?
Hi just wondering if anyone is using MKS or Outrage BL servos?
I had to space my servos by about 2 x metal plates thick to stop the servos from touching each other.
I was thinkin of putting the carbon arm on the inside of the 2 front cyclic servos and using the ball on possibly the inside to see if that will help geometry.
The rear servo I am not sure about yet but shouldn't be too hard.
Just wondering what others were doing??
Synergy E7 ~ Logo600 + 600SE ~ Synergy E5 ~ Synergy N5C ~ Mini Protos ~ Futaba 14SG
beans07 is online now        Reply With Quote
Old 02-16-2012, 06:14 PM   #2
beans07
Hi all got it sorted out.
I managed to get the spacing just right. The synergy E7 is the only (besides logo600) setup I have ever had on vbar that has 0 points trim, 0 ponts swash level and 0 points needed at top and bottom stick . I would say I got the geometry for vbar is perfect.
-I used the carbon horn behind the plastic horn on all 3 servos.
-ball facing the front.
-1 x carbon spacer from Trex600/700 (2-3 synergy metal servo plates) on the front 2 cyclics and none on the back cyclic servo.
-Used the setting in the manual for the servo linkage.
Old 02-17-2012, 08:30 AM   #3
beans07
I also out the nuts on the back closest the servo and used the dremel just to take the end of the bolts so they don't foul the servo.
Old 02-17-2012, 10:56 AM   #4
Weule
+1 - The head geometry is perfect for the MicroBeast as well.
Weule is online now        Reply With Quote
Old 02-17-2012, 05:17 PM   #5
beans07
The actual ball spacing on the carbon arm is a little too far for vbar as I am pretty well at the top of the limits in vbar. I will try it but might need to run some other servo horns that are a little shorter.
Old 02-17-2012, 10:16 PM   #6
stevehof
You want to be around 90 to 110 on the Vbar setup graphs. That's the sweet spot for most servos and the Vbar control loop. Shorter arms would not be desirable unless you are way over 100.
2 - Synergy E7, Vbar 5 Pro, BLS255 & 256HV, Hacker Turnado 530 Edition/Quantum 4530-500, Rail 696/716, CC120/160HV, WR Sup BEC, Scorp BUG | Trex 500 ESP, ICE 75, Hacker 1600KV, 5245MG & 9254, BeastX, head/swash | Futaba 18mz
stevehof is offline        Reply With Quote
Old 02-17-2012, 11:17 PM   #7
beans07
Thanks for information. I have about 9 different vbar helis and set many more up. The geometry is probably the worst for vbar control loop on any heli I have seen. I guess it was designed around a different brand of FBL.
The figures are not where I would like them. I am at 110 on collective (about 12.5deg) and maxed on 120 for cyclic (8 deg).
I will source some new servo arms for around 18mm I think. The standard ones I think are about 20mm.
Old 02-18-2012, 09:16 AM   #8
stevehof
I just checked my E7 vbr file and I am at 97 for 12.5 collective and 105 for 8 cyclic. I believe Matt used Vbar in early development of the E7. I'm pretty sure he used Futaba servos too. I am using Futaba servos. Maybe the MKS servo is slightly different in travel range...In any case, I am very happy with the FBL setup on my E7.
Old 02-18-2012, 09:46 AM   #9
beans07
I will see how it goes first. If it is good I will leave it otherwise I will get some BLS HV servos for it.
Old 02-28-2012, 09:18 PM   #10
wicked_n_raw
I am using the torq servos with a spacer behind the aileron and pitch servo's. Everything lined up perfect. I am also using the v-bar and I am not having any interations on the mainshaft at all.
ID:	294423   Click image for larger version
Best Regards
Furron
Goblin, Pulse Ultra, Canomod
wicked_n_raw is offline        Reply With Quote
Old 02-28-2012, 09:32 PM   #11
beans07
What sero horn and ball distance?
I am having issues being on the limits of vbar which will need me to go a couple of mm in on the ball to get it in the right range.
Old 02-28-2012, 09:53 PM   #12
wicked_n_raw
I used the small futaba wheel with the carbon servo wheels in the kit. Be careful, I had to find a way where the screws for the carbon rods do not scratch up the servo.
Sent from my PG86100 using Tapatalk
Best Regards
Furron
Old 02-28-2012, 10:01 PM   #13
beans07
I have also done this but the ball spacing puts the vbar at the very top of it's limits.
Old 02-28-2012, 10:23 PM   #14
wicked_n_raw
I can't remember which on but I dialed the cyclic ring back to 80 or 75 in the swash menu.
Best Regards
Furron
Old 02-29-2012, 07:39 AM   #15
beans07
Sorry I have had a brain fade.
I need to go out for more throw.
Maybe some longer balls on the swash would do the trick?
