Old 02-18-2012, 11:16 AM   #1
u8at711
Default broken main frame
I did not think it was possible, after all the crashes in the past and how bad they were, Finally smoked the main frame,
started practicing piro flips on the 450, after the maybe 8th one, it was too far out and the sky was cloudy,
well, it ended up in the ground,
the anti taco plate got a slight taco, bent feather shaft, main shaft, slight bend on flybar, broke one tail blade, killed canopy, everything else is A OK. did not even bend tail boom so it must have been a direct hit.
took these pic's before touching the heli, Cool crash !
ID:	290829   Click image for larger version
Gaui X3, NX4, X7, NX7
Empire Hobby Team GAUI USA
Team BK Servo, Switch Rotor Blades
Pulse Battery Rep
u8at711 is offline        Reply With Quote
Old 02-18-2012, 11:23 AM   #2
Rahulgaba
Niiiice crash! Looks cool! Hahah!
I had a similar one, but there was a bunch of dry grass.. Like a lot of it ... It cushioned the blow.. Nothing broke ... Except .. Motor mount was bent. Go figure! Lol
Whiplash 700 Gasser TRM VX300TT
Whiplash Nitro 91 HZ-R 3D & Hitori
VIBE 50 big block OS 91 HZ-R IKON
JR X9503
Blade 180CFX Gaba
Rahulgaba is offline        Reply With Quote
Old 02-18-2012, 03:07 PM   #3
wkma7six
Very cool crash. I thought you planted it like that for laughs til I saw part of the canopy mount was still holding a piece of the canopy and the flybar was wrapped up a little.
wkma7six is offline        Reply With Quote
Old 02-18-2012, 06:13 PM   #4
avrflr
Default Way to augur in
That is some nice lawn dart action! Great effort
avrflr is offline        Reply With Quote
Old 02-18-2012, 07:51 PM   #5
u8at711
just finished the rebuild,
those main blades are totally shot, the battery strap tore in half,
and one of my MKS95 servos jumped a tooth, and has a tight spot,
going to order up some new gears for it, but going to fly it anyways till they show up
main gear got stripped.
now that I have servo damage,
but a 410 servo would have been totally wiped out.
Pulse Battery Rep
