Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X7
X7 Discussion and support of the Gaui X7
Old 02-19-2012, 08:54 PM   #1
irishmatt18
Default Issues, Solutions, Tricks.
What issues have you had with your build or during set up?
What solutions did you come up with if needed?
Any tricks for building this bad boy?
irishmatt18 is offline        Reply With Quote
Old 02-19-2012, 10:23 PM   #2
ragtop01
misdrilled canopy holes. off enough to be irritating. but the tail case awesomeness makes up for it
"just let it happen"
ragtop01 is offline        Reply With Quote
Old 02-19-2012, 10:45 PM   #3
irishmatt18
I love a good looking tail.
Old 02-20-2012, 02:02 AM   #4
akamullen
Who doesn't...
AnythingHeli.com OWNER/ TEAM PILOT
GAUI X5 / X7 *
GOBLIN 500/630/770 * TREX 500DFC / 450DFC@6S * Swinging EDGE & SAB Blades * Microbeast/IKON * Castle ESC's on all * Beating on all
akamullen is offline        Reply With Quote
Old 02-21-2012, 05:36 AM   #5
bjb714
I misaligned the boom support ends when I CA'd them on one of the rods. My own fault.
I tried to pull them apart but...too late, I broke the rod.
Now I'm waiting on some replacements from Mullen. I know I should have been more careful, but a slot in the rod and a tab on the end for alignment would have idiot proofed it, which I apparently need!
Whiplash • Gaui X7 • X5 • Compas 7HV • Outrage Fusion 50 • Protos 500 Stretch • Align T-Rex 500 ESP • 450 Pro (x5) • 250 SE • Blade 130x • Nano • DX8
bjb714 is offline        Reply With Quote
Old 02-21-2012, 06:18 AM   #6
Matt Nasca
I don't think CA will be a strong enough bond. It would be best to rough up the carbon ends a little and use Epoxy. If you stage the tail boom clamp on the boom, epoxy the ends on the supports and then mount the boom supports,it will hold everything in place while the epoxy dries.
GAUI X7 - GAUI X5 - GAUI NX4 - GAUI X4 II - GAUI X2 (R.I.P.) - All on VBar 5.3 Pro
GAUI USA / Scorpion Motors & ESC / Scorpion Competition Packs 65C+ / Spin Blades / YS Engines / VP PowerMaster
Matt Nasca is online now        Reply With Quote
Old 02-21-2012, 07:01 AM   #7
vr360
30min epoxy sitting overnight would be ideal, but you can get away with using the 5minute stuff
vr360 is offline        Reply With Quote
Old 02-21-2012, 07:45 AM   #8
akamullen
I have undone CA'd ends from a tail pushrod by just touching a soldering gun to the metal end for a few seconds to heat it up, the ca let loose for me very quickly when I did this.
Hope this helps for next time..
Dave
GAUI X5 / X7 *
Old 02-21-2012, 12:31 PM   #9
xfactor6
Default frame divider posts
did anyone have any issues with these lining up? i cross threaded mine so i had to get a new cf divider. i know i could have hacked something up to put a nut in there and a longer bolt but wanted to do it right. is there a trick to lining them up? its very tight fitting
xfactor6 is offline        Reply With Quote
Old 02-21-2012, 03:44 PM   #10
Rollin_3z
Are you talking battery divider? If you are,make sure you tap the tabs all the way forward. Its a tight fit, but it will move forward another 2-3mm and then the holes line up.
Gaui X7, Trex 450
V Bar Pro
Rollin_3z is offline        Reply With Quote
Old 02-21-2012, 03:55 PM   #11
xfactor6
yup maybe thats why, i just forced the screws in and it stripped(since it wasnt lined up). ill tap it like you suggested. Thanks,
Old 02-21-2012, 04:46 PM   #12
Rollin_3z
No problem..Another quick tip, this was hard to tell from the manual..use the special servo spacer on the top two alieron bolts. It stops the canopy from binding the links
Gaui X7, Trex 450
V Bar Pro
Last edited by Rollin_3z; 02-21-2012 at 04:58 PM.. Reason: It is in manual, but not very noticable
Old 02-21-2012, 04:56 PM   #13
akamullen
No problem..Another quick tip, this was omitted from manual..use the special servo spacer on the top two alieron bolts. It stops the canopy from binding the links
Nice find...
GAUI X5 / X7 *
Old 02-21-2012, 05:00 PM   #14
Rollin_3z
Just edited my post, it is in the manual . Too quick on the build and missed it the first time.
Gaui X7, Trex 450
V Bar Pro
Old 02-21-2012, 05:11 PM   #15
akamullen
I have not gotten to servos yet, so I'm right with ya. I'm waiting for all electronics to show up before I dig back in to the build and finish it up..
GAUI X5 / X7 *
Old 02-21-2012, 05:18 PM   #16
frito169
Default build
My motor should be in by Thursday. Can't wait to test this out.
frito169 is offline        Reply With Quote
Old 02-21-2012, 06:12 PM   #17
irishmatt18
Being that I don't have one yet, not sure what that will be but is it obvious what the servo spacers are and where they need to go?
Old 02-21-2012, 06:13 PM   #18
akschu
I used a little too much thin ca to glue the bearings on the torque tube and seized a bearing. I had to take the heat gun to it to break up the ca then clean it really well with debonder, then re-lube with some grease and a touch of triflow. It works fine now.
Also, I found that my TT gear didn't mesh very right on the main gear so I removed the smallest shim from between the top of the main gear to the bearing block. It's much tighter now, but I can still get some paper between the gears.
It took took a little while to find the right tension for the tail pitch slider link bolts. To tight and the tail binds, but you don't want that to come apart. I found that some red locktight and just snug was the sweet spot.
I didn't have any issues with pinion mesh. I put the motor as close to the main gear as I could and found that if I wiggle the main gear and can detect just the slightest amount of play which is perfect. I usually set my gears up this way. I make it as tight as I can while I can still detect some play. It doesn't need much, just enough that the gear isn't bottomed out. Everything moves freely.
Another thing I found was that the savox high volt servos don't work on anything less than 6v without jittering. I set my CC BEC pro to 7.5 and they are way happier (and fast!). I don't trust the bec pro on 12s so it's wired to use only one of the 6s packs.
With the BEC pro, savox servos, spyder 6s5300 batteries and the 7200BX spektrum/beastx, KDBB tail blades and align 690D main blades, the heli came out pretty light at 11.5lbs.
schu
akschu is offline        Reply With Quote
Old 02-21-2012, 11:28 PM   #19
Rollin_3z
"It took took a little while to find the right tension for the tail pitch slider link bolts. To tight and the tail binds, but you don't want that to come apart. I found that some red locktight and just snug was the sweet spot."
Mine was the same..the bushings are a tad too small, so when you tighten the bolt, it binds the link (You might get a slow wag on hover if your pitch slider not smooth).
Irishmatt, on page 27 it shows the servos without spacers and on 28 it shows the servos on the frames. I''ve built a few helis already, so when I got to that part, I braided my servo lines,hid the wires and setup my head geometry without double checking manual..lol
Gaui X7, Trex 450
V Bar Pro
Old 02-23-2012, 02:08 AM   #20
vr360
Did everyone remember to remove and loctite the set screw that holds the pin in that keeps the rear torque tube output gear from moving?
