Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mSR X
mSR X Blade Micro SRX Helicopters Information and Help
Old 02-20-2012, 05:52 PM   #1
Dont155
Default Chicken Dance?
Anyone else ever have the X do a little chicken dance on you AFTER throwing TH switch? Mine does it every once in a while even after I throw the throttle hold switch and chop the throttle. Gotta be hard on the main motor and the board...
-Don T
Spektrum: DX7s, Blade: mSRX, mCPX, 130X, 180CFX
$$$ + Heli Hobby =
Dont155 is offline        Reply With Quote
Old 02-20-2012, 07:38 PM   #2
Gryffandor
I have had the same thing happen on more than a few occasions
Gryffandor is offline        Reply With Quote
Old 02-20-2012, 07:55 PM   #3
Flatearthman
Amat victoria curam:
Victory loves careful preparation
Flatearthman is offline        Reply With Quote
Old 02-20-2012, 07:58 PM   #4
Liduno
Sounds like the throttle hold isn't working, the board will eventually turn off once it gets enough resistance, like you said that's not good for any thing.
Liduno is online now        Reply With Quote
Old 02-20-2012, 08:00 PM   #5
Dont155
Nice to know its not just mine. After the first two times it did that, I went over the TX settings with a fine tooth comb just to make sure I had it set right. Its really annoying to watch it hop around like that when you KNOW you've hit the TH just before crashing.
I've walked up to it and heard the motor still straining, then it cuts off and it starts flashing the LVC indicator at you. Not sure why it doesn't get the cut-off signal from the TX...
-Don T
$$$ + Heli Hobby =
Old 02-21-2012, 03:55 AM   #6
petedee
Nope never had this problem. How about posting video of this.
similis vobis fugere eam furatus
"The beatings will continue until morale improves."
-- William Bligh
petedee is offline        Reply With Quote
Old 02-21-2012, 08:07 AM   #7
wulfrun
It's happened to me, once with the mSR X and many times on the mSR. As far as I can tell, it only happens if the blades can't turn freely, i.e. the motor is still under a high load. Half the point of TH is to cut the motor in these exact conditions, so I've always thought it is a design flaw. Hitting the throttle-cut button does not work either under these circumstances either, at least not immediately.
Belt CP/Blade 400 hybrid with RDTS mod
Blade mSR, Blade mSR-X, Blade mCP X (V1), Blade Nano CP X & QX
Buzzfly BE (aka Walkera 4#3B)
wulfrun is offline        Reply With Quote
Old 02-21-2012, 08:11 AM   #8
wulfrun
Not an easy thing to do, unless you just happen to catch it doing it while you had the camera rolling anyway.
Old 02-21-2012, 10:05 AM   #9
Flatearthman
i have had it happen trying to land with the blue led blinking with the msr
throttle fully cut bfore landing
