| 120 SR Blade (eFlite) 120 SR Helicopters Information and Help |
#21 |
I just got my replacement solid shaft and I have fairly pronounced TBE. My suspicion is that the holes aren't drilled perfectly again. The vertical slop I had is gone and the hole size is better, but I can't keep the heli in one spot. Certainly not like this:
I have a brand new, factory stock main shaft I plan on installing tonight to see if it changes anything... |
#22 |
Yeamag, that looks like it is flying very good to me. I see no TBE, only a little movement, which you're always going to have. A 120 SR isn't going to hover like a coaxial. Even perfectly trimmed, it is going to vary its position in a hover.
#23 |
crashjack, he means that it doesn't fly like the heli in the video. As in, the video is an example of a good hover, and his heli doesn't hover that well.
#24 |
Oops, I jumped to the video too quickly without reading thoroughly. My apologies.
#25 |
I just replaced the solid shaft with a new stock shaft and it flys like the video above. Perfect. Something still isn't right with my replacement solid shaft. I've contacted the seller and will let you know what I hear back.
I was so confident I tried some forward flight today and the wind was just too much. Not that I'm really good enough yet, but damn... That's hard! |
#26 |
Update:
After the 2nd solid CF shaft was off (bottom hole was too high), I contacted the seller again and stated that I was willing to try one more time, but if the 3rd shaft wasn't correct, I wanted a refund to which seller was agreeable. I also asked him to compare his solid CF shafts to the stock shaft, which would enable him to see where he was off. He apologized and said he would go back and go over everything diligently before making and sending me a new shaft. I received the 3rd shaft and have now installed with no problems (holes were drilled straight, and the bottom hole was in the correct spot). The heli hovers quite well and quite smooth. I haven't been able to really "fly", but it hovers well so all should be good. It appears the 3rd time was a charm. I also want to say that though there were some problems with the first and second shafts, the seller always turned-around the replacements very quickly and was always willing to refund my money. He proved to me that he is serious about wanting to make these shafts right, and that he is willing to back-up everything he does. In the end, I recommend the shaft. I think the bugs have been worked out, and I like the idea of using a solid CF shaft. I do have 2 recommendations for anyone buying: 1) Stand the solid CF shaft next to the stock shaft to make sure the holes match. 2) Seat a screw in each of the holes (obviously the bottom hole, which holds the main gear, requires a little larger screw). If you know that you can seat a screw in each hole, you know everything will go back together, and if it doesn't, it is not the fault of the solid CF shaft. Though continuity from shaft to shaft might be in question, the seller’s willingness to make things right is not in question. My hope is that from now on the shafts will be drilled correctly. The good thing is, if you have a problem, you can always get your money back. |
#27 |
Nice to know we have a responsible sellar making parts for our little heli's.
Airshot |
#28 |
The shaft I received is solid and that's the only good thing. Darn it! James ![]() UPDATE!!!!!!!!!!!!!!!!!!! The top hole is crooked! It's lower down the shaft on one side to the other. Damn! |
#29 |
It's really a shame for both him and his customers. The guy ate the postage for the replacement he sent me, then refunded me the cost of the shaft and the postage on my original purchase when the replacement didn't work out.
I don't see how he can be making any money at this. |
#30 | |
I would pay for the postage. Well I sent him a message, lets see if he continues to be as helpful. James By the by, here is my seller: http://www.ebay.com/itm/330599659388...84.m1423.l2649 |
#31 |
That is the same guy. I don't know how much off the shaft can be and still produce good results. I have a strong feeling that the stock shafts aren't all perfect, either. My first stock shaft had bends, which resulted in a good bit of difficulty removing the anti rotation collar and the lower collar/spacer. I even had a heck of a time pulling the shaft through the frame. I also noticed that on my new stock shaft, the lower hole wasn't centered. I don't know that it matters, but it definitely wasn't centered.
#32 |
Cool!
Hi, I am very sorry about the defective shaft. I do make them myself and therefore take full responsibility for its quality. I will mail a replacement to you tomorrow and make sure to look carefully that everything is straight and even. Thank you very much for understanding. - rowenajo Beside me, I guess there is still some good sellers out there! |
#33 | |
I don't think someone can pull something like this off unless he has some pretty sophisticated equipment. |
#34 | |
The remaining holes are for the main gear and the retention collar. Their alignment is important only for balance reasons, and a little slop there won't make a huge difference. |
#35 |
The two holes that have to be the proper distance apart are the bottom hole (main gear) and the 3rd hole-- the next hole up (lower spacer collar). If not, you either won't be able to install the gear and collar at all or you will bind the whole shaft.
#36 |
James |
#37 |
2nd one came and I can't install it. The "solid" shaft cracked down the middle when the hub screw was screwed in. The holes are off center again.
I'm starting to really doubt this sellers abilities. James |
#38 |
That's really dissapointing to hear, I had very high hopes for the solid CF shaft...
Have you been in touch with the seller after this last one? I assume you'll be asking for a refund? |
#39 |
I'm leaving it in his hands to decide. I sent a message explaining the problems and ended it with "please advise".
I also sell on eBay so I don't want to be the kind of buyer who demands this and that or who threatens a negative feedback and such. From what I'm hearing about this seller is he will do right with the buyer and he does eventually produce a good one. So let's see what he says. James
DX6i / Brushless MCPX / 2 stock MCPX / MQX / 120SR / Scout |
#40 |
I just talked to the seller and 1 more is on the way.
