| 250 Class Electric Helicopters 250 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
I am thinking about getting a 250 size helicopter and of course Align keeps popping in my head. But would it be better to get the SE combo or a kit and add my own electronics? I've seen a lot of the SE combos for around 430 and a kit without everything for 164. Which is the better deal after adding everything up?
Synergy E5 vBar-BLS255/256-CC120HV-Scorpion-Rail Blades,v400D02, DX7s, RF 6.5 HeliPack, Past helis: a lot of Blade and Walkera // //www.inner3.com |
Well that really depends on what you're looking for. There's really nothing wrong with the stock electronics in the combo kit, and its a good value for the price.
However if you're one of those that wants the "best" as far as electronics go then you're better off just building the kit and adding in your own electronics. Again it just boils down to what your budget is and what you want out of the helicopter. Maybe someone else with a little bit more experience can chime in here..
HK450 V2. MKS DS92A+. MKS DS95i. Spektrum ar7200bx. JR X9503. CopterX 250 awaiting same set-up as the 450 |
Stock servos are great for the money, I usually stick with them, they're a great baseline.
Stock motor and ESC are fine, I prefer the CC25 becuase I like to use the set RPM gov mode and put in 3500, 4000, and 4500 as my target headspeeds. I would buy the Scorpion HKII 2206-3900 motor and use a 16T pinion. There's nothing wrong with the stock motor and ESC, but if I had to buy them, I wouldn't buy the stock Align parts. I would use the gyro from the combo... if I had to buy one it would be the Futaba GY520, or the Spartan Quark. Same thing on the gyro, stock is fine, but if I had to pay retail for it, I wouldn't get the 780/790. All of that will probably add up to more than the SuperCombo price. I believe that stock is fine, but if I could get a kit-only and put the slight upgrades I prefer, I'd probably do that.
TRex 250 DFC | TRex 250 DFC (Scale) 2 @ TRex 450 DFC | TRex 450 Pro 3G (Scale) TRex 550 DFC DX8 + Telemetery on all |
#4 | |
Yeah, Rotorquest here in Ontario seem to have about the best combo prices here. Right now you can get an SE super combo for about $330, or the new Pro for around $370.
I've never seen them get the 'kit only' ones though...
#6 | |
Most likely you will end up at least changing out the tail servo and probably the gyro. I have 5 Align Helis and the ONLY Align electronics left on them are The DS610 Cyclic servos on my 550E and the 700MX motor on my 700E (and that may be headed for a replacement) For reference, Todays Helidirect prices for the components I run on my 250 is a total of $428.00 Three Hitec 65MG servos for the cyclic ~ $30.00/servo JR DS3500G Tail servo ~$80.00 Castle Creations 25amp ESC ~ $68.00 Viper 3600KV motor ~$40.00 Futaba GY520 Gyro ~ $150.00 My 250 flys amazing with the above setup and TP 65C batteries Based on the prices that you gave it would cost you about $162.00 more than the super combo to put your own electronics on the 250 and in my opinion have a much better helicopter with no tail wag, no motor bogging, a tail that doesn't blow out on fast backward moves, and one that flys alot like a 450.
Jim Trex 250 ---- Trex 450 Pro ---- Trex550 FBL ---- Trex 700E FBL ---- Avant Aurora 90E ---- Goblin 700 Keep it off the Ground....but just barely
#7 |
this is a serious answer .. but if you have to ask get a combo .. IF you have to ask, no way you will out-fly it .. sure theres better setups, but ultimately more money and again, if you have to ask, you wont be able to utilize 'more performance' anytime soon .. just the way it is .. a combo is a solid setup for the money ..
#8 |
I agree with dze and actually meant to write something similar. A super combo will fly just fine in most hovering and sport flying. It is a good value. It really comes down to the kind of flying you do. I still maintain that you will at least change the gyro and probably tail servo. I did nothing more than change out the tail gyro and the 250 infamous tail wag was eliminated.
#9 |
I am humble enough to admit you are right. I have RTF helis so haven't had to deal with this before. But I'm ready to start pushing my flying, already doing tons of sim time and won't something to learn on, so the stock electronics should be good enough. Then as my flying progresses I can sway out some electronics and eventually move to a FBL head and beastx. my LHS has the SE for 329, far better price then I expected. I was looking at the walkera v200d03, but even the walkera guys are saying going for the trex 250. I love my new v120d02s, flies great, but for the 200 size it looks like I'm going for the trex. Will the build be all that difficult? Supposedly Align makes a manual that is pretty easy to follow. Doing the build so I learn every single part of the helicopter. Only been flying for 14 months so there is still more to learn.
#10 | |
The build is easy to follow but the parts are not easy to see. Make sure you get some type of magnifying device. A magnifying visor like below, not necessarily lighted. Also make sure you pick up a high quality hex driver, the one that comes in the kit is garbage and the screw heads are really easy to strip. I think the size on the SE is .050 inch but someone else will have to chime in on that. I have an old model partially converted to SE so I have a mix of sizes on mine. Don't over tighten the screws, they break very easily. Make sure to loc-tite everything, even the parts that are factory assembled but be careful not to get any on bearings and spacers. Finally, take your time and use this forum as a resource (make sure to use the search feature first). There is lot's of wisdom on here regarding building.
#11 |
Since this would be my first build would it be easier to do a trex 500 first?
#12 |
It would be easier because of size of parts and electronics/wiring placement. But the build will be very close as far as assembly.
#13 |
Yeah I'm going to wait until I get a larger helicopter. Either another 450 or 500 to do a build.
