Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 02-21-2012, 02:37 PM   #1
marcosp
Default Scorpion 4525LE Ultimate
So they finally decided to go with a YY winding!!!
http://campaign.r20.constantcontact....rVvtMtsuUjw%3D
Marcos
Banshee #27, 2x TDR, Diabolo, JR Sylphide E12, Voodoo 600, Voodoo 400, Avant Aurora 90N, Rave 450, Gaui X2
marcosp is offline        Reply With Quote
Old 02-21-2012, 03:41 PM   #2
rctintin
Oooow, perhaps I should not sell my spare Helijive now!
Henseleit TDR V-Bar
SAB Goblin 700 V-bar T-Rex 700e DFC pro HV V-Bar
Synergy N5c V-Bar YS56 T-Rex 700n V-Bar YS91 srs Futaba 18mz PL8x2
rctintin is offline        Reply With Quote
Old 02-21-2012, 04:19 PM   #3
abanihani
Done, ordered and i am ready now to order the Diabolo for this motor
"Yes, German heli addict"
Banshee #26, TDR, Vibe SG 12E Hiroki ito, Forza, Diabolo, Triabolo, 800 plus, Raptor E820, Logo 600sx, logo 600SE Uvular, Logo 600SE mikado Hughes scale, HD 500 (soon)
abanihani is offline        Reply With Quote
Old 02-21-2012, 04:35 PM   #4
spdntckt
in the text of that page it says that it has a 9 turn delta.. so i think the spec is wrong. .do we know what the actual wind is? like a 5+4 or something?
spdntckt is offline        Reply With Quote
Old 02-21-2012, 04:40 PM   #5
rctintin
I noticed that, but guessed that was the original specs for the first 4525LE
Henseleit TDR V-Bar
Old 02-21-2012, 06:41 PM   #6
abanihani
so did I make a mistake by ordering this one would it work with helijive
Old 02-21-2012, 06:50 PM   #7
rctintin
I read it that there will be no more 4525LE Delta wound motors. If you place an order now, or on a back order, you will get the new YY wound motor.
This should be fine with the HeliJive, as the 4530 and 4535 LE's are YY, and run fine on the Kon.
Henseleit TDR V-Bar
Old 02-21-2012, 07:18 PM   #8
abanihani
so my understanding it is more powerful than pyro 520, they both cost the same. I may try it on a second TDR kit if I decided to build that one, I am also thinking of Diabolo too, can't really make up my mind.
Old 02-21-2012, 08:57 PM   #9
Dumbthumb75
The Diabolo is a better choice for powerful LE motors. It has much more bracing than TDR, it is made to handle more power.
Diabolo build thread with good pics:
http://www.helifreak.com/showthread.php?t=382529
minicopter Diabolo, Henseleit TDR, MA Spectra-G, Raptor 50T
Futaba 2.4 GHz
Dumbthumb75 is offline        Reply With Quote
Old 02-21-2012, 11:27 PM   #10
Stolla
Next up let's hope they do a 4035 yy will have more power and better for likes of the tdr
Stolla is online now        Reply With Quote
Old 02-21-2012, 11:40 PM   #11
Blink 182
Will the YY work with the Kontronik Jive 120 for 3D flight?
I would like to have a larger motor for XFC.
The current 4525 will shut down with the Jive 120, im not intrested in changing ESC just for this motor.
(´・ω・`) ギルティクラウン
Blink 182 is offline        Reply With Quote
Old 02-22-2012, 04:00 AM   #12
Nexus665
In a word, yes.
YY terminated Scorp motors run very very well on Kontronik Jives, no matter whether during 3D flight or speeding.
Cheers,
Simon.
Nexus665 is offline        Reply With Quote
Old 02-22-2012, 06:02 AM   #13
Mercuriell
Not always. I run 4525s on my TDR and JOker3 with Jive 120 - never had a shut down.
John
Mercuriell is offline        Reply With Quote
Old 02-22-2012, 11:47 AM   #14
Stolla
Thing is with yy no need to run ksa and yes while you can get away with running the d non ksa etc, flying hard on a warm day you run very big risk of failure, very well documented.
Old 02-22-2012, 01:01 PM   #15
abanihani
Is that because the helijive 120 is not enough amperage wise or it is a thermal shutdown, if it was the later do you think the soon to come Kosmic 160A will help?
Old 02-22-2012, 01:37 PM   #16
jointer
Possible issue with low resistance motor, it is not temp or amperage problem.
Basically the Jive could "loose timing" so it stops working correctly in flight with possible damage for components inside Jive.
- TDR #2, 4525LE, YGE 160HV, MKS HBL950 (JR MP82S=crap), Outrage BL9188, Gryphon Quasar, silver Vbar + 2x sat, 12S Billowy 50C 5200mAh, Radix V2, EDGE 105mm, DX7
- TDR #1 sold (standart setup, 700+ flights)
- HPI e-Firestorm FLUX, Spektrum DX3S
jointer is offline        Reply With Quote
Old 02-22-2012, 02:21 PM   #17
abanihani
The IR of this motor is very close to my pyro 520 black edition, I would not think Kontronik will miss something like that, I started worrying now I will have the same problem as the black edition has low resistant wiring
Old 02-22-2012, 02:37 PM   #18
jhunter
Default I doubt very seriously that your k motor will have problems with a k jive.
My power jive worked great with my pyro and my 4525le. You will be fine.
TDR, Srimok N x 2, Banshee 31, Dune!
jhunter is offline        Reply With Quote
Old 02-22-2012, 03:41 PM   #19
rctintin
I understand the PowerJives are OK with the 4525LE, in fact I know 2 people running that combo with no problem.
The problem as I know it is the HeliJive with the 4525LE. Something to do with low IR delta wind motors and back EMF popping a diode in the HJ.
Henseleit TDR V-Bar
Old 02-22-2012, 04:03 PM   #20
jointer
That is new for me, it is only HeliJive problem, not PowerJive??
I thought it does not matter.
I have 4525LE in a box over a year and i do not want to use it with any Jive (and possibly loose a heli) so i save it for new build with YGE (probably).
