Old 02-21-2012, 05:43 PM   #1
whoanelly
Default Please Eflite come out with better servos
so tired of these dam servos causing the shakes,,replace one then they fly perfect. just a pain in the ass ..just had to vent.
700LE : 105HZR AR7200BX JR8917 Multi gov , JR9503
600ESP : 100AMP Castle. Scorpion Motor . AMA #962896
400 Blade : Scorpion 2221-6 ,Castle ICE 50 Sonix Head and t
Align 450 pro V2 3G MKS DS95 MSR , 2 x MCPX (brushless C05 & HP05), Blade 130X.
whoanelly is offline        Reply With Quote
Old 02-21-2012, 06:06 PM   #2
SuperBee364
http://www.helifreak.com/showthread.php?t=368904
SuperBee364 is offline        Reply With Quote
Old 02-21-2012, 06:11 PM   #3
poor_red_neck
That 2.3g servo isn't going to help any.
The problem is the method to know the position of the servo.
I'd like to give these a try from Hobby King. Using a gear system with a real potentiometer instead of a swiper.
http://www.hobbyking.com/hobbyking/s...dProduct=16270
Blade 130X - Stock
mCPx Brushless Stretch (125mm) - WK10A - 11000kv Inrunner - 550 mah - Full CNC Upgrades
Logo 400 - Parting Out - Need parts PM me.
Retired Helis - Outrage 550, Trex 500, Others
poor_red_neck is online now        Reply With Quote
Old 02-21-2012, 06:34 PM   #4
whoanelly
those look yummy,,wonder if any one else has tried them.?
Old 02-22-2012, 12:48 AM   #5
uh1medic
Yup. Can't stand the servos. Extremely difficult to maintain and service. I guess this is an inherent problem with tiny helicopters...too small. I have had fun, but losing interest quickly due to the above mentioned frustrations.
uh1medic is offline        Reply With Quote
Old 02-22-2012, 02:46 AM   #6
ZyBeR
I wonder if these have the same bolt pattern so they fit the mCPX?
Lynx Team Pilot
ZyBeR is offline        Reply With Quote
Old 02-22-2012, 02:51 AM   #7
poor_red_neck
Next time I order from HK, I'll pick one up. At $3 it's worth a try.
I don't have high hopes though. Maybe I can rig something if it doesn't.
Blade 130X - Stock
Old 02-22-2012, 04:34 AM   #8
Heli G
They just need cleaning and once you have done it properly with deoxit and also use the gold as a very thin cover your issues should be something of the past. Been 60+ flights since I've done that and still perfect.
Heli G is offline        Reply With Quote
Old 02-22-2012, 09:15 AM   #9
ahahn
I cleaned my servos for the first time back last summer, and that was the last time.
Mine (all 3) seem to be doing just fine. No shakes I can see.
ahahn is offline        Reply With Quote
Old 02-22-2012, 09:40 AM   #10
DudeInMyrtleBeach
There are a couple of things you can do to ease the pain. As previously mentioned, there's deoxit gold. This is a nice 'servo cleaning and protecting' kit:
http://www.amazon.com/Squeeze-Tube-K...9924495&sr=8-1
Use the cleaner first (red tube), then apply a thin coat of gold (gold tube).
The other thing, believe it or not, is to use a 'speficic' type of carbon fiber for the main shaft. I've been using the Great Planes stuff - specifically part number GPMR7790 - and when the swash rubs against it, it generates a fine dust that seems to be attracted to servos.
When I use this stuff from rcfoam:
http://www.rcfoam.com/product_info.p...522239f9d1f865
that doesn't happen as quickly. The rcfoam stuff has what almost looks like a 'clear coat' on it.
Interestingly enough, I found that thisis exactly the same stuff that is used on my (ebay) $3 training kit for the 450 I used to have. The 450 training kit came with 4 pieces of this cf, but only 2 were usable for main shafts(even close to straight). I got 9 main shafts from a $3 training kit. I'm good with that.
This is definitely as case of YMMV, lol.
DudeInMyrtleBeach is offline        Reply With Quote
Old 02-22-2012, 10:13 AM   #11
jabu32
do they have similar specs?
Hello My Name Is Joe
Blade mCP X BL - HP06V2 / Blade mCP X BL - Spin 16.3K / Blade 400 - DS760, 450MX / Trex 500ESP DFC - AR7200BX, 500MX / Trex 550e DFC - AR7200BX, 600MX
jabu32 is offline        Reply With Quote
Old 02-22-2012, 10:38 AM   #12
DudeInMyrtleBeach
If you check the 2.3g servo thread by Roffey, you'll find the answer...
The answer is that the stock 1.9g linears are designed to be 'on' and waiting for commands at all times. That's why they chatter. This is not typical servo behavior, and other servos (including the new 2.3g servo) just don't cut it on an mcpx.
Strange things can and probably will happen.
Old 02-22-2012, 01:13 PM   #13
whoanelly
I think its just one of those things that pisses you off when all is good then wham im shaking or wobbling and cant track it down like on a normal collective pitch heli,,to find out i have a durty servo is WTF..
