| Multi Rotor Helicopters Multi Rotor Helicopters Info and Support - Tandem, Quadcopters, Tricopters, Octocopters, and Hexacopters |
Building my first quad... trying to figure out the best way to:
wire the 4 esc to power - should I just solder them all together? is there a 4 into 1 plug somewhere that can be used or should make one with bullet connectors??? is there a "power distribution" board available? any pics would be great!!!
Team "Wife" sponsored pilot... Thanks Baby!!! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. AMA# 977810 |
#2 | |
Here are few pics of my power harness (that I soldered myself). Wires are 14AWG soldered together into a 5.5mm bullet connector, the other ends are each soldered to 3.5mm bullet connectors. Further down is my overall wiring: ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Perfect Arxangel! that is exactly what I had in mind... I did find a cool little distribution board, but I think your solution is simpler and I would have to "find" a place to mount the distribution board.
Thanks for you quick response!!!
Here is a 4 in 1 plug
http://www.hobbyking.com/hobbyking/s...er_1_set_.html |
#6 | |
